Author Topic: Any demand for blue 11/16" t-molding?  (Read 1565 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: January 18, 2006, 01:35:09 am »
I asked t-molding.com about getting the obscure size 11/16" in other colors (I would want blue). And he said he could special-order it if I buy the whole spool of 250 feet.
Would there be an interest here?
This unique width is the width used on Frogger-style generics (and maybe non-generics like Frogger itself?).
NO MORE!!
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
Re: Any demand for blue 11/16" t-molding?
« Reply #1 on: January 18, 2006, 07:32:38 am »
I don't need any.
Does the 11/16 vs. 3/4 really make that much difference? That would only be a 1/32 inch overlap on each side.
97.4 percent of all statistics are full of crap.
Dustin Mustangs
  • Last login:September 14, 2017, 11:43:18 am
  • Cut the sheet!
    • My Site
« Reply #2 on: January 18, 2006, 10:21:39 am »
It's a pretty standard practice in the (non-arcade) cabinet biz to install t-molding for countertops and such oversize and then trim it to size with a razor blade or sharpened chisle by laying it flat on each finished surface and running it along the t-molding.  It's a very quick and easy process as long as you don't gouge your finished surface (laminate in this case) and it makes for a flawless t-molding to finished surface interface even if your slot isn't dead nuts centered.  This might not work as nicely with an irrergular surface such as painted particle board like I am sure many around here would have but I thought it would be worth mentioning anyways.
RayB
  • There's my post
    • RayB.com
« Reply #3 on: January 18, 2006, 03:18:31 pm »
I'm using 3/4" on 11/16th" wood and there's no way I would attempt to trim it down. I doubt I could get a straight cut, and it would show. The whole point of t-molding is to hide the imperfections of the wood edges.
Regarding does it really look bad to have a bit of overlap? No. Doesn't look bad at all. But if I need to open my control panel, it rubs against the overlap (over time wears it down. makes it all ratty looking). Same goes if I need to pull the speaker panel out.
NO MORE!!
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
« Reply #4 on: January 18, 2006, 04:19:05 pm »
Try one of these trimmers. probably not as expensive as an exclusive run of molding.
http://www.rockler.com/product.cfm?page=1266
