Author Topic: Suggestions for removing smoke stains from a marquee?  (Read 1351 times)
2PacMan
  • Last login:November 06, 2009, 08:33:45 am
  • PacMan collection
« on: January 17, 2006, 01:52:35 pm »
I bought a Vs. Super Mario Bros and the marquee is badly stained a yellowish brownish tinge due to what i'm assuming to be smoke from years sitting in a bar.  Under the marquee brackets, the thing looks brand new.....anything i can do to remove this discoloration?  I tried soaking it in Oxyclean and several over the counter general spray cleaners, but nothing worked.  I'm worried if I use too harsh of a cleaner, it will eat away the print on the marquee.  The Vs. marquees are like vinyl stickers stuck to the outside of the plexi, so there is nothing covering the printing.
Luckydevil
  • Last login:August 02, 2007, 01:38:45 pm
  • mmmm.... kilowatts.
    • Garage Junkies
Re: Suggestions for removing smoke stains from a marquee?
« Reply #1 on: January 18, 2006, 11:55:39 am »
Maybe try some rubbing alcohol on a small part that doesn't show just to be sure it won't mess up the marquee. Then try cleaning it with alcohol on cotton balls.
Witchboard
« Reply #2 on: January 18, 2006, 01:47:29 pm »
I got one monitor that was so badly coated with nicotine and tar that I had to use paint thinner to cut it.  Obviously you can't use that on a plastic marquee, but maybe you can try Lift Off #1 or #2 or something.  They have a little kit at Home Depot with #1-3 and each one is more powerful than the last and it says it's safe for vinyl, lexan and plastic.
