Author Topic: two joypads in mame  (Read 1961 times)
J-Rod
  • Last login:February 10, 2008, 06:17:07 pm
  • Gaming junkie
two joypads in mame
« on: January 15, 2006, 11:51:21 am »
I have two USB gamepads, and it seems like mame sees them both as the same controller. Is this just the way mame is? Or is there something I can do to get them recognized as seperate controllers? I mean for now I can play the simple games that use only a couple of buttons, and map one controller to the analog and one to the digital pad. But what if we wanted two player Street Fighter? This poses more of a problem. Any input is appreciated. -JC
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: two joypads in mame
« Reply #1 on: January 15, 2006, 02:13:21 pm »
I had a similar problem.  I was using two identical gamepads and they were both plugged in right next to each other on the front panel USB ports.  I moved one of them to the USB ports on the back of the computer and my problem went away.
The front ports plug into a different USB header on my mobo from the ones on the back; I can only assume this is what made the difference.
J-Rod
  • Gaming junkie
« Reply #2 on: January 15, 2006, 09:06:20 pm »
Weird. Well I have my wireless pad hooked to the rear, and I have been hooking the other wired pad to the front USB plate. I guess I'll have to take a look at how the machine handles the USBs, now that I know mame indeed will see two seperate controllers. Thanks for the input!
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #3 on: January 16, 2006, 11:04:56 am »
Kremmit is correct (as usual).  Identical gamepads should be hooked up to different USB buses.
J-Rod
  • Gaming junkie
« Reply #4 on: January 16, 2006, 05:06:33 pm »
Indeed, Kremmit, you are correct. I must have had both my wireless controller and the wired plugged to the front while I was testing. I have since moved the wireless inside the box using a USB extension cable from the back ports, and all is well. Thanks so much for the help.
