Author Topic: Will a medium resolution game play on a standard resolution monitor?  (Read 3315 times)
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
Game with standard resolution is ult. mk3, want to play nfl blitz, anybody know if this will work as i have a standard resolution monitor to test, thanks
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
Re: Will a medium resolution game play on a standard resolution monitor?
« Reply #1 on: January 13, 2006, 11:40:12 pm »
Only if there is a dipswitch on your blitz pcb that allows standard res. output instead of med. res.  Alot of medium resolution games had this option, I don't know if blitz was one of them.
kjoel0123
« Reply #2 on: January 14, 2006, 09:40:03 am »
thanks for the input
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
« Reply #3 on: January 15, 2006, 11:00:16 pm »
I used to have blitz 99, and i dont think that is an option.  you will ned a med res monitor if u want to play this game.
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
SirPeale
  • Green Mountain Man
« Reply #4 on: January 15, 2006, 11:21:03 pm »
I know Blitz 2K was switchable, so the others may be.  Consult your manual.
sp0rk
  • Last login:August 30, 2007, 04:40:42 pm
« Reply #5 on: January 15, 2006, 11:25:13 pm »
I have blitz 99, it works fine in my cab (standard resolution)
It has a dip switch setting.  I honestly don't know what ones, I looked up the switch settings online, and they worked, just left it that way ever since.
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #6 on: January 16, 2006, 01:37:27 am »
Outside of board-level dip switches, some standard res monitors will downclock to accept 24-25KHz signals, although it depends entirely on the monitor itself.  If you have one of those monitors that simply switches itself off when the input is out of range, you can test for yourself.  Don't try it on monitors that don't switch off.  While you probably wouldn't do any permanent damage, I really don't recommend taking the risk just in case.
Popcorrin
« Reply #7 on: January 16, 2006, 11:13:06 am »
You're saying a standard resolution monitor can run at a higher scan rate?  I never heard of that.  I could see it the other way around, a medium resolution monitor being able to accept standard resolutions but not a standard resolution monitor being able to accept 24-25 kHz.
elvis
  • penguin poker
    • StickFreaks
« Reply #8 on: January 17, 2006, 01:54:39 am »
Ah ---steaming pile of meadow muffin---, sorry.  I meant medium res can sometimes play on hi-res (31Khz "VGA").  Not what I said above.  :o
At best, sometimes you can squeeze "extended" res (16KHz) out of standard res (15KHz) monitors, but again that can cause damage if you're unlucky.
Sorry about that.  It all got jumbled in my head.
