Author Topic: New Product: Electric ICE  (Read 21053 times)
Hockeyboy
  • Last login:April 17, 2022, 02:48:38 pm
Re: New Product: Electric ICE
« Reply #40 on: January 22, 2006, 07:57:09 am »
Okay, so let me ask the "not so sure if this is dumb or not" question:
If I bought these to use in my project, say 6 per 'player' for a total of 12, and then got some red, blue, and clear (or yellow even) LEDs to slide in underneath, I would need...what to complete them? Can you make them light up as the buttons are pressed? Can someone here give me some examples of how this would accentuate a project? Don't get me wrong - I think these are totally awesome, just wondering how I would insert them into my CP and get the benefits.
markrvp
  • NFL Expert
« Reply #41 on: January 22, 2006, 09:40:47 am »
Do a search for the LED-WIZ thread and the Translucent Pushbutton threads and you'll see examples and even videos of how people have implemented lighted buttons and controls.
mahuti
« Reply #42 on: January 22, 2006, 12:19:28 pm »
It's all still kind of new... with the Led-wiz and stuff, so there aren't many examples yet.
For years though, people have been using LEDs... just stead-on most of the time. With the led-wiz, it's pretty simple to program a lighting animation. Doing things based on an event (button pushing, game selection) gets a little more complex.
mahuti
« Reply #43 on: January 23, 2006, 01:30:51 pm »
Just got my stuff from GGG today.
Haven't installed yet, but here are my first impressions.
Buttons; The buttons are very white / slighly pearlescent in color. They don't look like white player 1/2 start buttons.  They're cooler in color and less milky colored. They have a similar look to those white soap / shampoo bottles that are white and slightly hazy / pearly. The look like pretty much any other button otherwise, except for the tiny hole in the bottom that just barely accomodates an RGB led. I did notice that a few of my buttons were a bit finicky about putting the button nut on. On a few of them, the positioning of the lead-in thread on the button was unfortunately located in such a way that the microswitch mounting bracket made it difficult to get the nut on. At first I thought they were screwed up completely, but it just turned out that I had to be a little careful about installing the nut. I wouldn't even mention it except that sometimes these things have to be installed in tight spaces, and I forsee some cursing during basic installation. They look to have the same build as regular buttons, though, so this may be a problem with other buttons that I've been fortunate enough to have missed over the years. On a whole, they're just buttons and are of excellent quality.
RGB-drive LED boards;
The boards are very tiny. For some reason, I just didn't expect them to be this big. I mean... the picture shows them to be about 3 inches across ;) They're QUITE tiny as you can see in the picture. The perspective with the quarter is a bit misleading... they're about the same length as a quarter. When you install them in the pushbuttons, they fit VERY snugly. Impressive really. I installed all of them with no problems. None were too tight, or too loose which says a lot for the execution of the build tolerances on both the RGB-drive and the buttons. Not that they need to be, but the RGB-drive boards are held in place by the microswitch. You will definitely not find frustration working with these in odd / dark spaces. They take almost no space beyond the button, so you should be able to install these anywhere that you can fit a microswitch. The boards can be installed in either direction... going WITH the microswitch or facing away from it. That doesn't seem like a big feature, but there are a few places on my machine where that will come in very handy.
One thing I would suggest is to definitely buy these prewired and resistored. It's not that cheap (2.xx extra each) but worth it as far as I'm concerned. The harness (as you can see) is absolutely solidly macine wired and perfect. You can see the 4 consumer wiring holes, labeled 1,2,3,4. They are VERY small. They look like they require 23 guage or smaller wire. Since I usually use 21 guage everywhere, I would have had to run out to The Shack to install myself. Anyway they're rock solid and I have no doubt that they will withstand more abuse than anything I could solder in. For you solder pros... you may not need them. I'm pretty decent with an iron, but those are just too small for me to feel comfortable with. One more bit of info... the preinstalled harness is about 2 feet long. If you have a frankenpanel... that might not be long enough to get where you need to go.
Anyway, I'm going to begin wiring up today. Screw it... I'm taking off work :D
I'm going to program a rough app today to set the behaviour of the led-wiz based on the game called. It's not going to be some amazing program, but I'll share it when I'm done. To begin with... it'll probably just check an ini file against the name of the game. I don't PWN @!! T3H R()MZ to I'm only going to be worried about it running less than a few hundred lines. If I get ambitious, it may check the mame .cfg file but I doubt I'll get that far. Anyway, I'll keep you posted.
mahuti
« Reply #44 on: January 24, 2006, 07:01:43 am »
I've got them installed and wired up.
You can watch the video
The files 9mb, though. Sorry.
« Last Edit: January 24, 2006, 10:59:11 am by mahuti »
RandyT
  • Last login:March 23, 2026, 04:09:24 pm
    • GroovyGameGear.com
« Reply #45 on: January 24, 2006, 10:47:23 am »
Can't find proper CODEC.   :'(
mahuti
« Reply #46 on: January 24, 2006, 10:55:13 am »
I'll make it an mpeg. (was a mov...)
mahuti
« Reply #47 on: January 24, 2006, 10:59:43 am »
Updated. Now an AVI. A nice, outdated, old-fashioned AVI.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
« Reply #48 on: January 24, 2006, 07:58:40 pm »
Good stuff, I think you convinced me to order some goodies.  Thanks Mahuti.
MYX
    • MYX Digital Blog
« Reply #49 on: January 24, 2006, 08:25:26 pm »
Tripod ;D
M    Y    X
mahuti
« Reply #50 on: January 24, 2006, 10:41:37 pm »
Yeah, when you're walking back and forth to control the games and shoot at the same time, you can't be Scorsese. Too cheap for a tripod :P
