Author Topic: What kind of connector for interchangeable CP's?  (Read 2126 times)
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« on: February 06, 2003, 04:53:03 pm »
I know a lot of folks have made interchangeable CPs, but what type of connector do you use? I searched but couldn't find much. 25pin connectors?
I'm interested in building more than one CP and need a solution to quickly connect each one both to an optipac and ipac4 player.  Thats a lot of inputs.  Probably gonna need a couple of different cables, though if there is one big one out there that'd be cooool.  Are there any special cables made for this type of quick-disconnect with a lot of pins?
Thanks all! :)
Jungle
  • Last login:March 05, 2006, 08:38:19 pm
Re:What kind of connector for interchangeable CP's?
« Reply #1 on: February 06, 2003, 05:12:38 pm »
I think you can get some SCSI cables that are 50 pin...not sure of anything larger than that.
eightbit
  • My cab is never done...
« Reply #2 on: February 06, 2003, 05:43:26 pm »
32pins in a floppy cable, 40 pins in IDE, 50 or 68 pins in scsi. 25 pins in serial extension cables. I used serial extension cables and this worked great for my 2p control panel.
Don't use printer cables.
Larry Smith
  • Last login:September 01, 2004, 07:27:11 am
« Reply #3 on: February 06, 2003, 11:12:30 pm »
Whats wrong with printer cables? They work fine in my cab.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 06, 2003, 11:17:27 pm »
He answered in another post.  Basically printer cables don;t always come with all the wires as they aren;t needed most of the time.
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #5 on: February 06, 2003, 11:27:41 pm »
Yea I found this out the hard way!  I did find that the easiest way (for me) to get the wiring right is to use flat ribbon cable.  Very easy to find and cheap to buy.  I used 3 25pin cables for my panels.  1 cable for player 1, 1 for player 2, and one for aux controls and opticals.  Seemed to work out great.
ED7
eightbit
« Reply #6 on: February 07, 2003, 08:22:26 am »
Printer extension cable will work and its exactly the same thing as a serial extension cable, most regular printer cables won't.
quote author=electricd7 link=board=1;threadid=4824;start=0#31271 date=1044592061]
How many buttons do you have on your control panel?  Unless  you wired all your grounds seperately or have a whole bunch of administrative buttons 1 25 pin should have been enough.
Frostillicus
  • Arcade Artist
« Reply #7 on: February 07, 2003, 11:03:08 am »
Well, one joystick has at least 4 inputs(not counting grounds), so I think my original idea is to somehow make a cable that would utilize all the 4playerIpac AND some inputs on an optipac.   If I wanted to make a 4-player CP I'd need more than a 25 pin connector.  4 joysticks alone would be 16 connections(plus one ground). After looking for scsi cables(68 pin) on the web, I've found that they are rather expensive.
electricd7: How durable are ribbon cables?  Are you using the internal HDD ribbon cables? Seems like they'd get shredded if you change them a lot.
After some consideration, I think I'll just make a setup like 1UP's rotating CP.  Maybe scaled a little bigger like the regular one I already made(for D9200).  I think it'd be a great project and would eliminate not only this connector problem but I wouldn't have extra CPs cluttering up my apt.  Plus it's just darn kewl.  8)
Thanks all for the input!   ;D
