Author Topic: Sega monitor  (Read 1951 times)
rookie
  • Last login:January 07, 2006, 09:11:44 pm
  • Experience, learning from one's own mistakes
Sega monitor
« on: January 05, 2006, 07:50:39 pm »
As the name implies, a rookie here.
I have a Nanao MC-2000-S monitor. When I first got the game I did not have any manuals and the monitor was sitting free in the case not connected to the rest of the chassis because the previous owner had a cap kit installed. I powered it up not noticing the screen shield wire was hooked to the narrow/wide post on the main board instead of the neck board where it belonged. Probably OK till I joined the chassis back with the monitor frame, (oops) Blew the main power transistor Q901 and the small .8 amp fuse, but surprisingly not the main fuse.
Ken Layton
  • Guru
  • Technician
Re: Sega monitor
« Reply #1 on: January 06, 2006, 01:26:40 am »
That Sega/Nanao manual is widely available to download from places like arcadehelp.com and bombjack.org
There are some electrolytic capacitors inside the flyback cage that when dried up cause vertical collapse/shrinkage. Perhaps a replacement got damaged?
There's also a fusible resistor in the vertical circuit that may have opened up.
« Last Edit: January 06, 2006, 02:46:20 am by Ken Layton »
rookie
Re: Sega monitor
« Reply #2 on: January 06, 2006, 07:09:51 pm »
Thank you.
I have a much better print now, I can almost read it.:)
My main power is down to 96 volts from the 105 listed with less than 1/2 volt AC on it, probably from changing the transistor.
Ken Layton
  • Guru
  • Technician
Re: Sega monitor
« Reply #3 on: January 06, 2006, 07:22:07 pm »
Check capacitor C523 (under the cage around the flyback) which is a 47 uf @ 50 volt capacitor.
Check fusible resistor R416 (near the flyback cage) which is 22 ohms, 1/4 watt. Also check the vertical output transistors Q401 and Q402 (they are generally both type 2SD1138).
rookie
Re: Sega monitor
« Reply #4 on: January 07, 2006, 01:45:26 am »
Cool! got it!
