Author Topic: Black Gallagher Mini  (Read 2590 times)
teetu
  • Last login:January 17, 2016, 03:29:31 pm
« on: January 02, 2006, 03:22:20 pm »
Before I made a full sized cab, I thought I would start off by making a small one.  I had only previously made some sticks to use with consoles, so this was a tremendous learning experience.  I was only able to fit 2X4 ft pieces of mdf in my car, so it ended up being a 2/3 scale galaga.  I made it slightly wider to accomodate the TV.
It's pretty standard except for a few minor differences.  I mounted a 4 way sanwa underneath the 1/2" CP so that the stick was lower like it was on the original machine.  I also used some smaller sized sanwa buttons for the 1&2 player buttons since they were more to scale (i kept the fire button big though).  Next time i get some sanwa/seimitsu stuff, I'll get a smaller ball top (yah i know its not a big deal). I actually didn't put the tv in yet, but i'm pretty much finished wiring up the 4 in 1 that its going to run.
I have to say kinkos came through for me big time, as they only charged me $32 for the art (CP, sidearts, and kickplate on vinyl).  Even though I thought the cab construction was mediocre, finishing strong with the art really made it look good.  Although it took a while to get it, the marquee from emdkay lights up very nicely and is very well done.
I'm gonna need ure guys' help when I start making my full sized (i'm still doing rough sketches).
« Last Edit: January 02, 2006, 03:27:23 pm by teetu »
teetu
Re: Black Gallagher Mini
« Reply #1 on: January 02, 2006, 03:29:32 pm »
one more for no apparent reason...
Bones
  • [Moderator]
« Reply #2 on: January 02, 2006, 03:33:10 pm »
Very, very nice!
Hard to tell it's a mini though without some type of size reference.....
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #3 on: January 02, 2006, 05:31:55 pm »
Looks very nice.  Good and clean.  What electronics are you using?  Mame? Arcade PCB? Jakks handheld?
Harpal
  • Last login:April 02, 2006, 12:02:22 pm
  • I'VE STARTED BUILDING MY FIRST MINI ARCADE!!!
    • 3D-ARCADE at MAMEWORLD
« Reply #4 on: January 02, 2006, 06:42:52 pm »
it looks lovely......
just wished mine was turning out like that :-\
HAPPY NEW YEAR!!!!!
---------2006-----------
teetu
« Reply #5 on: January 02, 2006, 07:56:33 pm »
i'm just putting a jakks in there, because it's not going to be used much with the full sized mame machine in the same room (i'm gonna start cutting for it any day now!)
Harpal, I only have very basic knowledge and skills- you can make a cab that is at least as good as mine if not better.  You can slack all you want on the construction- you can compensate alot when you do the finish.  Take your time to prime and do several coats of paint (i sanded in between) and don't slack on the art.
Harpal
« Reply #6 on: January 02, 2006, 08:19:29 pm »
dont think you will say that after you seen mine.... ;D
http://forum.arcadecontrols.com/index.php?topic=47324.0
HAPPY NEW YEAR!!!!!
