Author Topic: Keyboard hack  (Read 1306 times)
SithMaster
Keyboard hack
« on: December 30, 2005, 11:55:00 am »
Im cheap.
« Last Edit: December 30, 2005, 11:59:08 am by SithMaster »
rdagger
Re: Keyboard hack
« Reply #1 on: December 30, 2005, 12:23:22 pm »
Take 1 of the inputs from the left of the board and make it your common.  This will go to the grounds on your controls.  Then use 9 of the pins from the right for your individual inputs.  You will probably need to use 1N4148 diodes on each of the pins on the right to prevent ghosting.  Play around with the pins to find the best  combination of keys.  You probably want to map every key to make this decisions.  BTW:  You won't be able to run Perfect 360's, rotary joysticks or other controls that don't use switches.
whammoed
  • Last login:June 02, 2026, 10:49:42 am
  • Crack don't smoke itself
    • NiceMite
Re: Keyboard hack
« Reply #2 on: December 30, 2005, 12:27:53 pm »
I have hacked a keyboard with a header like that.  I removed the header (use a solder sucker or solder wick) and soldered the wires to where the header was.  But, you may be able to secure the wires to the header, I don't know.
Post the numbers that appear on your pcb.  (the board you removed from the keyboard)
I may have hacked the same one in the past and if so I will give you the matrix map.
SithMaster
Re: Keyboard hack
« Reply #3 on: December 30, 2005, 01:40:08 pm »
the numbers are
qtronix 27-050-150
qwin95-a.pcb
84.12.08
and 9704
whammoed
    • NiceMite
Re: Keyboard hack
« Reply #4 on: December 30, 2005, 01:40:46 pm »
the numbers are
qtronix 27-050-150
qwin95-a.pcb
84.12.08
and 9704
I'll check tonight.
SithMaster
Re: Keyboard hack
« Reply #5 on: December 30, 2005, 01:41:46 pm »
that was quick thanks i apreciate it.
whammoed
    • NiceMite
Re: Keyboard hack
« Reply #6 on: December 31, 2005, 08:07:25 pm »
Sorry, don't have a map for that one.
SithMaster
Re: Keyboard hack
« Reply #7 on: December 31, 2005, 10:38:02 pm »
thats fine thanks for looking.  then ill try to make one with the chip still connected and if that doesnt work ill try it without.
