Author Topic: minimum CP height  (Read 2473 times)
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
minimum CP height
« on: February 04, 2003, 04:49:43 pm »
I'm starting to build the box for my standalone CP this evening. I've made my layout but all my parts haven't arrived yet. I'm not sure what the minimum height clearance I need is. I'm using j-sticks and horizontal micro switch pushbuttons from ultimarc and a betson trackball unit. Thanks in advance.
Re:minimum CP height
« Reply #1 on: February 04, 2003, 05:21:42 pm »
I would allow 40mm for the J-stick (actually ~37mm including the metal plate).
But for the pushbuttons you need to allow 60mm (actually ~56mm but don't forget spade connector!)
Sorry I can't help with the trackball depth, but it is probably more than the above measurements...
