Author Topic: Joystick mouting problem/question  (Read 1011 times)
ooby
  • Last login:December 27, 2005, 11:29:46 pm
« on: December 27, 2005, 10:43:26 pm »
G'day all,
I have a question/problem that I hope someone can help with.  I'm building my first cabinet and it's come time to put the control panel together.
I have bought the Competition Joysticks from Happ controls and I cannot get them together properly, the shaft of the JS doesn't go through the bottom far enough to attach the cir clip to it.  I think that the spacer is too big
Has anyone else had this problem or am I doing something totally stupid?  I don't really want to grind off some mm's off the shaft either
Any ideas?
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
Re: Joystick mouting problem/question
« Reply #1 on: December 27, 2005, 10:52:20 pm »
Sometimes the handle gets stuck in the base before it gets down all the way.  Jiggle it a little bit and push down.  Also keep in mind that you will have to push it down really hard to compress the spring enough for the e-clip groove to be exposed below the actuator (square plastic thing).
As I re-read your post I am reminded that a lot of new arcade things require brute force to get them together the first time.  Don't be afraid to push on it.
ooby
« Reply #2 on: December 27, 2005, 11:28:32 pm »
Thanks for that - solved my problem.
We were trying to push down the shaft but we had to push the bottom end to compress the spring and attach the cir / e-clip
