Author Topic: How do I mount Slikstik Tornado spinner in metal CP?  (Read 2727 times)
  • Last login:June 26, 2026, 12:10:33 pm
« on: December 22, 2005, 03:41:32 pm »
When I attach the spinner knob, it sits about 3/4" from the metal CP (presumably to accomodate a plywood CP).  Is there a way to make the knob sit lower or is there any way to shorten the shaft for the knob?  Damn that sounds dirty.
whammoed
  • Last login:Yesterday at 01:38:56 pm
  • Crack don't smoke itself
    • NiceMite
Re: How do I mount Slikstik Tornado spinner in metal CP?
« Reply #1 on: December 22, 2005, 03:44:16 pm »
Can't remember exactly, but there are allen set screw(s) you loosten to lower the rod.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #2 on: December 22, 2005, 03:50:23 pm »
Either use washers or nylon inserts between the top of the spinner plate and the bottom of the CP to lower the spinner so that the knob is just above the CP top.
Or just find the allen set screws whammoed mentioned.
« Reply #3 on: December 22, 2005, 04:07:33 pm »
Awesome - thanks guys.  I found the allen screws but man are they tight!  I can't get them to budge....
Also, do you think using some strong double sided tape would hold the spinner in place?  I need to mount it completely from underneath (without using the screws)..
markrvp
  • NFL Expert
« Reply #4 on: December 22, 2005, 04:22:36 pm »
I feel 100% certain that the double sided tape wouldn't work.
What if you took a couple of pieces of wood and notch them out and glue them to the bottom of the CP with an adhesive that will bond wood & metal.  Then you can slip the spinner in from the side, and use set screws from below to push the spinner up tight against the CP bottom?
Be sure the shaft will come out or slip all the way down before gluing the wood to the CP, otherwise the spinner wouldn't slide in with the shaft sticking up.
whammoed
    • NiceMite
« Reply #5 on: December 22, 2005, 04:40:59 pm »
Why can't you mount it with screws?
I attached mine to a piece of aluminum flat bar and made 4 holes in the flat bar spaced the same distance apart as joystick holes, then mounted it to my cp so the carriage bolts would line up with the joys.
« Reply #6 on: December 22, 2005, 04:49:27 pm »
« Reply #7 on: December 22, 2005, 04:50:52 pm »
I am covering my CP with a layer of vinyl and I want a clean look - there are black carriage bolts for the joysticks but nothing else.  No other real reason I guess...
whammoed
    • NiceMite
« Reply #8 on: December 22, 2005, 04:54:15 pm »
Gotcha...hope you find a suitable glue.
« Reply #9 on: December 22, 2005, 05:27:08 pm »
I'm thinking something like this:
