Author Topic: help with clearing a mapping  (Read 2742 times)
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« on: February 01, 2003, 05:19:07 pm »
When in MAME and using the TAB key to configure controls, how do you clear out a mistake when mapping a key? I can't find it in the docs?
J_K_M_A_N
Re:help with clearing a mapping
« Reply #1 on: February 01, 2003, 06:05:44 pm »
Hit enter to remap a key and hit any key several times. It will either go back to the default key (that game only) or it will set it to none (all games config). Then just hit enter and enter the key you want to use. Good luck.
J_K_M_A_N
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: February 01, 2003, 06:22:08 pm »
ESC (or the key mapped to "UI Cancel") will clear out the line.  Press enter like normal to edit that line, then press ESC.  Works differently in the general vs this game menus.  In this game, the input is set back to the default.  In general, the input is set to none.
Robin
Knowledge is Power
str1der
  • Live it!
« Reply #3 on: February 01, 2003, 06:35:33 pm »
Thanks for the info.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: February 01, 2003, 06:51:48 pm »
If you happen to accidently map tab to enter (like I did once) then you need to delete the mame/cfgs/mame.cfg
eightbit
  • My cab is never done...
« Reply #5 on: February 04, 2003, 07:41:36 pm »
Or if you happen to clear the mapping to the tab key like I did once.  :)
  • Last login:August 16, 2026, 01:35:00 am
« Reply #6 on: February 05, 2003, 12:22:57 am »
a good reason to use the ctrlr files... those menu keys are in the std.ini ;)
Jakobud
  • Last login:May 25, 2026, 02:04:14 am
« Reply #7 on: February 06, 2003, 02:33:11 pm »
What the hell are you talking about?
To clear a mapping just hit enter like you are normally going to remap it. And while it is waiting for you to hit another key just press ESC (or whatever key you have set for UI-Cancel) and it will come up as being mapped to NONE.
