Author Topic: Wobbles and Flickers.  (Read 1003 times)
drumlogix
  • Last login:April 25, 2006, 09:51:13 pm
  • MK-MAME Project.
« on: December 07, 2005, 07:08:59 pm »
Hi,
   I am working on a mame project and I recently had my k7000 recaped. When i have it hooked to the mk2 pcb it works fine and doesnt wobble or anything. But I have xp running with avga+jpac. i get wobbles constantly. I have tried running mame in 640x480,640x288 and set default refresh rate at 60 and still i get wobbles. The image and color quality is great but the screen jumps horizontaly slightly. Its more noticable from a bit of a distance. Does anyone else have a k7000 and have figured out how to fix this? Am i running in the correct refresh rate for this monitor? (60)? Thanks for any suggestions.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: Wobbles and Flickers.
« Reply #1 on: December 07, 2005, 11:19:23 pm »
Try running 640x240.
288 is 50hz, and 480 is 60hz interlaced...
I've used both a 19 and 25" 7000 with the avga and they both have very good pictures.
Also, are you using a shielded vga cable to go to the jpac?
Is you monitor grounded to the cabinet ground?
How about the computer? Grounded plug to earth ground?
Just a few things to try.
Later,
dabone
fredster
  • It's all good!
« Reply #2 on: December 08, 2005, 10:05:01 am »
Can any WG7000 series be hooked up to a standard VGA card?
