Author Topic: Dreamcast backup question (solved)  (Read 2523 times)
daywane
  • GRRRR!
« on: December 07, 2005, 09:32:00 am »
I have a few dreamcast games I was starting to have problems with.
I found them on a websight as back ups. came on DVD
I burned them no problem. ( .CCD format) (Clone CD)
well. I thought I could just use Clone CD to burn a secound copy of my burned disks.
( before you scream FOUL!!!) I just wanted to have a set at my cabbin so I do not have to transport my disks back and forth.
I got to my cabin and no disk would work.
I had to pull out the DVD and use Clone CD to burn the CCD files from the DVD
I must be doing something wrong.
« Last Edit: December 07, 2005, 05:11:50 pm by daywane »
daywane
  • GRRRR!
Re: Dreamcast backup question
« Reply #1 on: December 07, 2005, 04:53:01 pm »
 I found this on a google search.
Copying a Selfboot game with DiscJuggler:
Open 'DiscJuggler'.
Select 'New' and then choose 'CD Copy from the Same Recorder'
Insert the game you want to copy into your burner
In the 'Action' box choose 'Write'
In the 'Advanced' tab choose 'Overburn' and leave the other settings as they are
Hit 'Start'. It will create a temp image on your hard drive.
Insert a blank CDR in the drive
Press 'OK'
giving it a try
THATS IT! works fine ;D
« Last Edit: December 07, 2005, 05:11:02 pm by daywane »
