Author Topic: Still having Mamewah List problems  (Read 1234 times)
rbarr110
  • Last login:January 28, 2026, 12:10:10 pm
  • I already built my own arcade controls!
« on: December 06, 2005, 12:18:29 pm »
OK - still having problems with custom lists in Mamewah, after trying to figure it out, I found a video tutorial on where to put the catver file and what mamewah options to select.
http://www.screenshotarchive.com/mwtutorial.htm
However, after watching the tutorial, several of the Game List Options (Custom Games List in particular) shown in the video are not there on my machine. ( I am aware that the video is for an older version of Mamewah)  The only options I have in "Game Lists Options" is (if I remember correctly, not at home now) is "Generate List", "Main", "Favorites", and "Find Game".  I have done generate list and all it does is update the "Main" list.
What am I missing or need to do different?  I am using version 1.61 and mame 0.99.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Still having Mamewah List problems
« Reply #1 on: December 06, 2005, 12:22:56 pm »
You need to create an ini file for each list you want...
default is mame-0.ini
copy it to mame-1.ini
example of each ini file:
### mame-0.ini (mamewah v1.62) ###
list_title                                All Games
### Games List Settings ###
cycle_list                                1
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline
post_emulator_app_commandlines
### Settings used by MAMEWAH ###
current_game                              27
### mame-1.ini (mamewah v1.62) ###
list_title                                Classics
cycle_list                                1
list_type                                 normal
display_clone_info                        0
max_favorites                             0
current_game                              6
Once you have more than one ini for mame you will be able to select the list in the menu... othewise you will only get one.
Happy Gaming!
