Author Topic: PSP Vectrex emulator  (Read 7131 times)
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« on: December 03, 2005, 11:46:09 pm »
Well I wasn't sure if I should put this in Project Announcements, Software, or here.
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Re: PSP Vectrex emulator
« Reply #1 on: December 04, 2005, 09:12:17 pm »
im so there...<------1.5 here
TATE?
« Last Edit: December 04, 2005, 09:15:16 pm by DYNAGOD »
Enjoying the fruits of technological obsolescence one game at a time...
Stingray
« Reply #2 on: December 05, 2005, 01:32:58 pm »
I don't own a PSP (yet), but I'm a big Vectrex fan. Thanks for making this happen.
-S
Samstag
« Reply #3 on: December 06, 2005, 01:03:29 am »
So far there doesn't seem to be much of a crossover between Vectrex fans and PSP emulator fans.
Franco
« Reply #4 on: December 06, 2005, 04:08:00 am »
I don't know a lot about Vectex but I have a 1.5 PSP. I will check it out tonight and see if I can get it running. Ill post back later.
Franco
« Reply #5 on: December 06, 2005, 07:18:41 am »
See I can't even spell it right!
Samstag
« Reply #6 on: December 06, 2005, 08:56:38 am »
Thanks that'd be great.  I think it should be runnable on 1.5 but it's possible that you'll get an error message saying it can't find or open rom.dat.  If that's the case then I have to change the way I get the rom path.
« Reply #7 on: December 06, 2005, 09:41:05 am »
If I had a PSP I'd be all over it too, huge Vectrex fan here.  If I ever have a PSP it won't be until they're under $100 though.
Franco
« Reply #8 on: December 06, 2005, 10:15:39 am »
Yeah it works fine on my 1.5 no problem. I copied the folders as per the Readme and it started up no problem, straight off the memory card, even though I have had issues running other emulators on my PSP.
I thought that the fire button wasn't working for a start but you just cannot see the bullets. I don't know if you could originally. It may be beacase the resolution or something (im no expert) isn't correct in the same way that you cannot read the text easily as you stated and so they are too small to show up.
Anyway I hope this is of some help and good job so far, Im off to blast some more asteroids!  :)
Stingray
« Reply #9 on: December 06, 2005, 10:21:58 am »
Same deal here. I won't buy one until they get significantly less expensive. Once I do have one, I expect this to be one of the first things I download for it.
-S
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #10 on: December 06, 2005, 10:54:14 am »
-S
Hmm by that time it will be almost impossible to buy ones with 1.5-2.0 firmware.
Curls in the squat rack !?!?!
Edgedamage
« Reply #11 on: December 06, 2005, 10:58:57 am »
Also I tested it and it works. Also I got the seamonkey pack and have been causing trouble at work with the sony remote. There is a wega tv in the lunchroom and have been using the psp to switch channels on the tv and swtich it off. The fools at work think I am playing a game.
« Reply #12 on: December 06, 2005, 11:50:24 am »
By that time the unit will be end of life and there will be tools to change that.
Samstag
« Reply #13 on: December 06, 2005, 11:52:17 am »
Thanks, guys.
Stingray
« Reply #14 on: December 06, 2005, 03:21:15 pm »
Exactly.
-S
Samstag
« Reply #15 on: December 08, 2005, 01:06:30 pm »
Version 1.01 is now available as the first public release (1.0 was limited to BYOAC ;)).
The only significant changes are a big improvement in video quality (It's full of stars!) and I integrated Mine Storm into the executable where it belongs.
« Reply #16 on: December 08, 2005, 01:07:30 pm »
Awesomeness.
Samstag
« Reply #17 on: December 09, 2005, 03:54:54 pm »
Woohoo!
I just made the front page at PSP Updates.
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
« Reply #18 on: December 10, 2005, 11:04:34 am »
looks like you're on maxconsole.net also
http://www.maxconsole.net/?mode=news&newsid=5638
Samstag
« Reply #19 on: December 10, 2005, 12:33:38 pm »
Doh!  I should have submitted something to them since Zeus tends to miss important info in his news posts.  Like the author of the port, and the fact that he made the broken version available.
