Author Topic: switching out joys to p360  (Read 1276 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« on: December 02, 2005, 06:20:57 pm »
I have a SlikStik Classic with Competitions for the 1 and 2 player joystick.
 I want to swap the 1 player out and install a P360.  The problem is that the competition (and all other joys) use the COM and NC for each microswitch, while the P360 just uses the direction wires and 1 ground (along with the 5v).
Since the competitions have been daisy-chained together with other buttons and such, will I break the "chain" if I just leave the unused connectors unconnected?
Or do I have to somehow connect all of the wires (which I won't be using anyore) back together from the old competition?
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:June 25, 2026, 08:02:25 am
  • I am t3h GAY!!!
Re: switching out joys to p360
« Reply #1 on: December 02, 2005, 08:13:29 pm »
You should be just fine leaving them disconnected.
They are chained through the common wire, not through the switches the wire connects to.
Think of it as a pearl neclace. You have the pearls on a chain. You take some of the pearls off, the chain still connects. It may look a little uglier, but it functions still the same. The connections on a common ground to the switches are like the pearls. The important part is the wire underneath em. :)
deadmoney5
« Reply #2 on: December 02, 2005, 09:37:26 pm »
thanks vers...
now I just have to figure out where the 5v tap is on the ipaq
