Author Topic: vplaunch4 mamewah problem  (Read 1420 times)
brophog
  • Last login:January 20, 2019, 03:49:41 am
« on: December 02, 2005, 02:06:04 am »
OK, got a problem I cant seem to track down. I have a new install of both mamewah 1.61 and visual pinball 7/pinmame 1.52.
I installed vplaunch4 correctly in the tables folder. It has it's corresponding cfg file folder there.
I can launch a table from visual pinballs editor. I can also launch a table from vplaunch4. I can't, however, launch one from mamewah. I always get the 'RunTime 52' error.
[code]## vpinball_161.ini (mamewah v1.61) ###
emulator_title
brophog
Re: vplaunch4 mamewah problem
« Reply #1 on: December 02, 2005, 02:36:52 am »
Found the problem. Lose the quotes when you pass in the rom name.  [name] is good enough.
Some tables seem to lose focus though with pinmame. You either see the pinmame screen or you lose control of the table. sttng is a felon of this. Not all tables are having this problem though.
