Author Topic: Need Mamewah help, creating game lists  (Read 2628 times)
digitalpackrat
  • Last login:April 20, 2013, 07:05:52 pm
  • Cabinet currently in progress
« on: December 01, 2005, 01:24:33 am »
First let me say Mamewah is amazing albeit overwhelming
I used to use mame32 and really didn't need to create lists but I want to use a frontend in my cab to tidy up all these emulators.  I've been playing around with mamewah and got looking for stuff online and found a site that had premade game list generator for all games in my mame folder but  i would also like to create lists for:
favorites
3+ player games
fighting games
etc
but don't have a clue on how to go about it now that i'm using mame (v. 1.02b) command line version.
How do you change the text size for the game list?
also how do i get mame to stop showing the disclaimer?
digitalpackrat
Re: Need Mamewah help, creating game lists
« Reply #1 on: December 02, 2005, 10:54:20 pm »
No one knows how to make game lists?
I'm learning more and more everyday as I try to muddle through it on my own.  I found the mamewah config program that works with v1.61 of mamewah and its a great addition to helping new people with mamewah but as i learn more about mamewah I'm finding it better to just edit the ini files by hand alot of the times but it helps out alot in showing you all the features in mamewah.  so far it is the only program i've found to create game lists fairly easily.
When creating a list in mamewah is there anyway to have it look for more than one extension?  for instance sega megadrive (genesis/32x machine) roms come in .bin, .smd, and .32x extensions and while fusion can view all of them i can only get  mamewah and mamewah config to detect one extension
The learning curve is huge for a newbie like me for mamewah and all these emulators but it is slowly getting easier.  I've managed to get mame, sega mastersystem and N64 working (thx for the wrapper jcrouse)  still have like 15 more systems to go.
fillup
  • Last login:October 16, 2006, 08:39:16 pm
« Reply #2 on: December 04, 2005, 07:09:17 pm »
As of right now I think Mamewah can only see one kind of extension for each emulator.  You can set up multiple emulator INI's for the same emulator just having different names and have each show its own extension (ie KegaFusion but have a different INI for sega genesis, 32x, and game gear)  In effect each will be treated as a seperate emulator.  I am a newbie to so I am just learning as well.  Hope this helps
Pez4Brains
  • Last login:October 29, 2022, 05:49:51 pm
  • I built my own arcade controls!
« Reply #3 on: December 05, 2005, 11:29:25 am »
While this isn't anything that adds anything to mamewah, many emulators support roms in zip files.  Once all your .bin/.smd/.*s are in individual zip files you shouldn't have too much to worry about as far as mamewah lists go, just finding an emulator that supports everything else you want AND zip files.
digitalpackrat
« Reply #4 on: December 05, 2005, 01:00:44 pm »
thxs for the help guys.  yea the zip format seems to be the best way to go because many roms for the same system come in multiple extensions.  whats the best program to individually zip all the files in a folder?  i've been using power archiver which has a batch option to individually zip all the files in a folder but the dumb program also adds the file extension to the zip name as well as adding underscores where spaces belong.  i then thought to try the good tools rom renamer and it seemed to work properly for the most part with my n64 roms, only a few were renamed to the wrong file name (i'm trying to get my file names to match those of the screens and boxart found on screenshotarchive.com) but when i did my genesis files it messed up most of them.  for example my genesis roms would have a (a) or (5) at the end as well as the screens from screenshotarchive but the good tools renamer would change them to (U) or (E)  any ideas?
Pez4Brains
« Reply #5 on: December 05, 2005, 02:02:40 pm »
Well, I don't have any bright ideas to rename your genesis stuff back to what they were, but the Generic Artwork Renamer on screenshotarchive.com seems like it may be able to rename the images to match the new file names...I'd make a backup first this time around though.  Something in my gut tells me this might put kind of damper on updated the roms or screenshots in the future, but I don't even know if that's something to be worried about.  If it's less complicated than that though, and the only difference is that (a)->(U) and (5)->(E) something like RenameMaster (http://www.joejoesoft.com/vcms/108/) would fix it in no time flat with it's Replace fuction.  It even has a preview and an undo function.
As for a way to zip everything in a folder to individual zip files, I'd say try winrar.  Open it up and navigate to the folder you're looking for, select everything you want to zip and click the Add button up top.  When the next box pops up remember to choose zip instead of rar for the archive format, and then go to the Files tab and check the box that says Put each file to separate archive.
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #6 on: December 06, 2005, 12:28:29 pm »
You could always get a new romset. They do exist with with all .bin extensions. 8)
(same for the snes!)
digitalpackrat
« Reply #7 on: December 06, 2005, 09:18:39 pm »
that renamemaster sounds interesting i'll have to give it a try.  man my genesis roms are the worst of the bunch  i just finished setting up the last of my console emulators and i had very little trouble with the rest of them (in terms of mamewah, finding the right bios for mess for the 7800 was a challenge) such as atari 2600-7800 and turbo grafx 16, my rom names matched the picture names just fine.  its a shame there isn't a good emulator for the atari jaguar  i've been wanting to play some brutal sports football or cannon fodder.
any idea where i can get my hands on an organized genesis collection including screen shots, box, and cartridge art?
just have the handheld emulators to setup now and i'll be done then just doing the little tweaking like adding the no image pics.  Mamewah is an excellent frontend  I really like it.  It just takes alot of patience and research  not all the information is found in the docs.  the mamewah config program is great as well as help from jcrouse's website, screenshotarchive, and arcadecab.com.  timoproduction has some nice skins also
spongebue
  • Last login:April 20, 2006, 03:50:32 pm
« Reply #8 on: December 09, 2005, 05:34:37 pm »
hello,
could someone answer his (and now mine, I guess :P ) question about making custom lists?  I cannot figure that out if my life depended on it.  Right now I have the default setup, and it works fine, but there are so many clones and games I don't really play that it gets to be overwhelming.  I'd really appreciate a quick response, as I have company coming soon and I'd like to have this done beforehand :)
Thanks,
spongebue
metaHipster
  • Last login:January 10, 2010, 06:09:19 pm
  • Taking the next level to the next level
    • MetaHipster's Arcade Blog
« Reply #9 on: December 14, 2005, 08:09:22 pm »
here's how I got it to recognize the full name/metadata for all games via Mamewah Config 1.6.1
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=57702&page=&view=&sb=5&o=&fpart=1&vc=1
I don't think I mentioned there that catver.ini (http://www.catver.com/) is required for your mamewah setup to be capable of filtering by category.
You can do all of this without Mamewah config (there's a utility built-in to mamewah called make gamelist - access by hitting 2 to get to yer menus and then it's under the options).  You'd still need mame.dat and catver.ini to best of my knowledge...
good luck.
