Author Topic: Trackball Questions - Please Read  (Read 2324 times)
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
« on: January 29, 2003, 08:38:48 am »
I want to do a control panel with 2 players 6 buttons each, 3" happ's trackball with 2 buttons, spinner with 2 buttons and a 4-way with 2 buttons! I plan to cover it with Lexan!
What's better: 1/16, 1/8 or 1/4 lexan????
Should I buy a high-lip trackball or a normal trackball???
Thanks!  ;D ;D ;D ;D ;D
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
Re:Trackball Questions - Please Read
« Reply #1 on: January 29, 2003, 09:25:41 am »
I've made a total of three panels, and have found the 1/4 lexan to be the *only* way to go, especially with what you are planning.
My first panel used 1/8 lexan and I had to drill three lexan panels before it worked correctly.  The problem was that when I would drill out the 6 buttons that close together, the panel would lose strength and shatter (one time during drilling my last button, argh!).
I bumped up to 1/4 and it was so much stronger and easier to handle.  The only downside is it took longer to drill through, and, of course, was a little more expensive.  I also thought that it looked and felt much sturdier/stronger/better when I was done with it.  I also didn't have any fears of it cracking when people were really hammering the buttons playing a game, I was always worrying about that happening with the 1/8 lexan.
As far as the trackball, I used the normal but I'm sure it is just a personal preference
ripzone
« Reply #2 on: January 29, 2003, 09:40:59 am »
So, you are happy with 1/4 lexan over a trackball.
I think you mounted the trackball in a mounting plate over the lexan.
I want to mount the trackball using a mounting plate but under lexan (flush) so the lip should be short!
Give me your opinion please
Sorry for my ---smurfing--- english!
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #3 on: January 29, 2003, 10:03:48 am »
If you can afford a high-lip trackball, I would go for it... but they are VERY expensive.
remember that you can get bensen 2 1/4" ones for about 40 bucks and replace the ball with a real pool ball... Just to give yourself some perspective.  Sure they are smaller (centepede size) but for the price you can get multiples.
I went with a cheap 3" one from ebay myself
ripzone
« Reply #4 on: January 29, 2003, 10:42:12 am »
The 3" high-lip ball is less expensive than a normal 3" happ's trackball.
RandyT
  • Last login:June 18, 2026, 02:39:45 pm
    • GroovyGameGear.com
« Reply #5 on: January 29, 2003, 10:43:17 am »
If you have a router, you can use thinner materials without the shattering problem.
The best approach is to make all the holes in your wood, mount the lexan over the panel, drill a hole large enough for the laminate-trimmer bit to pass through and then just clean it out with the router.
Keep good down pressure and watch for chatter though.
RandyT
eightbit
  • My cab is never done...
« Reply #6 on: January 29, 2003, 01:44:07 pm »
A good forstner bit would probably solve your problem, I used 1/8 and it turned out marvoulessly.
ripzone
« Reply #7 on: January 30, 2003, 12:12:30 pm »
with just a normal 3" trackball or with a high-lip, eightbit???
eightbit
« Reply #8 on: January 30, 2003, 04:32:32 pm »
It wasn't for a trackball it was just for an overlay. I was responding to Ashardin who was having trouble drilling holes close together.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #9 on: January 30, 2003, 10:32:05 pm »
I'd go high lip & 1/8" or 1/4" lexan.  If you do 1/8" + the high lip, the lip should align with the top of the lexan if you mount the trackball under the lexan (& route out 1/16" of the wood for the mounting plate).  The 1/4" is stronger, but then I'd say mount the trackball on top of the lexan, which is not as pretty.  My $0.02.
Robin
Knowledge is Power
