Author Topic: Tips for cutting into acrylic?  (Read 1298 times)
chadandjody
  • Last login:April 17, 2011, 06:56:40 pm
« on: November 26, 2005, 02:51:52 pm »
Any tips for cutting a square hole into a sheet of acrylic?
Knievel
    • Knievel Kustoms
Re: Tips for cutting into acrylic?
« Reply #1 on: November 26, 2005, 05:48:19 pm »
Not sure why you want a square trackball hole but if you have a router it's the best for working with acrylic/plexi.
I would make a template with a hole sized the way you want it in a scrap piece of MDF. Then clamp your plexi over the template, with the hole in the required location. Then just plunge through the plexi using a router with a straight plunge bit, run it around the perimeter of the hole and you're done.
chadandjody
« Reply #2 on: November 26, 2005, 06:36:02 pm »
The trackball kit I bought has a black mounting faceplate on it that fits around the trackball.
