Author Topic: Pinball problems  (Read 3625 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
Pinball problems
« on: November 26, 2005, 02:55:09 am »
he hehe Grrrrr.  heze help :-\ :-\ :-\
Frigging pinball. malfunctioning.
It is 1976 Williams Space Mission
Worked fine yesterday. Today, it scores when you hit the flippers, and it starts resetting in the middle of a game. Additionally, there is a loud buzzing noise when I first turn it on.
Any suggestions? I have both the manual and the schematics.
Sometimes I wonder if it would have been better to ask Santa for a nice football...
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
menace
Re: Pinball problems
« Reply #1 on: November 26, 2005, 07:41:54 am »
hmmm check the usual suspects, loose plugs into main board and from playfield to head?  any burned marks on the mainboard anywhere? Does the game have a diagnostic where you can test switches, flashers,solenoids?
I would unseat every connection to the mainboard (clean if necessary) and re-seat them first thing first.
« Reply #2 on: November 26, 2005, 09:52:31 am »
None of those things are going to work.
It's an EM.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 26, 2005, 10:10:17 am »
Ah yes, good old Space Mission. I remember it well. We had several of them on the routes in the late 70's. They were good earners!
As to the scoring problem, check for a playfield switch (usually a standup switch) set too close or getting stuck. Reset/buzzing could be the main reset bank coil (the giant red wrappered coil) pulling in/getting stuck. Could even be something simple like the lock relay on the bottom panel humming/buzzing from dirt/corrosion on the armature flap. Also the coin lockout relay (that rejects coins when the machine is off or in the middle of the score motor cycle) is known to hum from a bind in the linkage.
USSEnterprise
    • USS Odyssey
« Reply #4 on: November 26, 2005, 12:34:27 pm »
I should also let you know that the previous owner of this machine really screwed things up. Apparently, he didn't know of the relatively simple way of enabling free play, so he rewired the whole damn machine. Now the coin mechs, credit wheel, and anything relating to the coin system are disabled.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: November 27, 2005, 12:59:05 pm »
Wow Ken. You never cease to amaze me. Sounds like you're much older than I thought! ;-)
NO MORE!!
USSEnterprise
    • USS Odyssey
« Reply #6 on: November 27, 2005, 01:25:27 pm »
Just thinking the same thing
Virgil Tracy
  • Last login:October 27, 2008, 04:53:20 am
    • www.virgil.tk
« Reply #7 on: November 28, 2005, 05:45:37 am »
My Liberty Bell has the same issue, I am off to look at the switch Ken ahs described
