Author Topic: Betson Multisync works with Golden Tee Fore PCB!  (Read 1444 times)
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« on: November 22, 2005, 03:15:30 pm »
I'm trying to decide whether or not to buy a Golden Tee Fore PCB kit.
« Last Edit: November 26, 2005, 02:40:19 pm by markrvp »
StephenH
Re: Betson Multisync for Golden Tee Fore PCB?
« Reply #1 on: November 26, 2005, 01:52:34 am »
If you have the multisync that does 15-38Khz, it should be OK.   CGA res is 15Khz, and Medium Res (EGA) is 25Khz.
markrvp
  • NFL Expert
Re: Betson Multisync works with Golden Tee Fore PCB!
« Reply #2 on: November 26, 2005, 02:44:33 pm »
Okay, I just got my Golden Tee fore 2005 PCB and it does work with the Betson Multisync 27"  The monitor chassis has a six pin connector (just like a CGA monitor) where you plug in the R,G,B,Ground,Sync lines.
If someone were wanting to buy a monitor to use with a Golden Tee board, then IMHO this would be a better solution than an EGA-only monitor as you can always use the Multisync later on for anything else you want.
