Author Topic: PSX pad to Ipac help!  (Read 2688 times)
Cilrider
  • Last login:March 15, 2020, 08:27:40 pm
« on: January 26, 2003, 12:34:58 am »
 ???-This is on the Ipac messageboard to  ;)
So im hacking a PSX controller and wiring it to my arcade right? So I have everything wired to the joysticks/buttons (etc). and it works fine. The only problem I am having is when I go from my ipac to the barrier strip it acts like theres a current running through it and its just a constant "s" or an "a". Anyone understand what im trying to say? Long story short...Wire goes from button 1,2,3 etc on the Ipac to X,O,TRI,SQ on the barrier strip. Whenever I connect them it acts like a constant press is being pushed down.  ??? ??? >:(
Any thoughts.....if anyone can help I have some pics of it I can send. thank you.!
Or maybe if anyone knows how to wire a switch (pics would be awesome).  A switch so I can switch between the IPAC and PSX....(printer switchter maybe?!?)
« Last Edit: January 26, 2003, 12:37:01 am by Cilrider »
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
Re:PSX pad to Ipac help!
« Reply #1 on: January 26, 2003, 01:08:54 am »
If I understand you correctly, you have...
Joysticks/Buttons  --->  PSX controller  --->  I-PAC  --->  PC
OR do you have
Joysticks/Buttons  --->  PSX controller  --->  PC
AND
Joystick/Buttons  --->  I-PAC  --->  PC
In either case, I guess I don't understand what you are gaining by using two different interfaces (I-PAC & PSX) to connect your controls to your pc.  I think you would just run into problems by trying to do this, and from your post it seems that you are.
« Last Edit: January 26, 2003, 01:12:16 am by x-wing »
Cilrider
« Reply #2 on: January 26, 2003, 01:32:53 am »
(Also when I press down my buttons on 1 and 2..they output the same button  [ex: a,s]>:(.......(ahhh so many problems!)
Im using my arcade controls for MAME and PSX
(What im doing marked with '*')
So whenever I touch a wire from the barrier strip to the ipac I get a constant continuity......like its being held down.
Your first one...like this :
((PSX CONTROLLER)
|      |   |                                            *This is button 1 on IPAC4*
(0)(*0*)(0)(0)barrier strip)                    (*0*)(0)IPAC4)
(Arcade controls)
« Last Edit: January 26, 2003, 02:09:52 am by Cilrider »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: January 26, 2003, 02:44:06 am »
Crisis solved on chat with a MUCH better idea:)
eightbit
  • My cab is never done...
« Reply #4 on: January 26, 2003, 09:15:46 am »
How?
SirPoonga
  • Puck'em Up
« Reply #5 on: January 26, 2003, 04:24:24 pm »
How?
arcade controls to a db25 plug.  then a ahcked psx controller will have one end of the plug and the ipac the other end of the plug.
SNAAAKE
  • -Banned-
« Reply #6 on: January 26, 2003, 04:25:49 pm »
How?
That is EXACTLY what i was gonna post..except i was thinking molex connecter but DB25 should be better(less work).
