Author Topic: Xbox controller hack  (Read 2440 times)
SithMaster
« on: November 18, 2005, 07:39:36 pm »
Which is the best xbox controller to hack the s, a pelican, gamestop, fps master?  I wanted an fps master but i read they are flimsy and arent respnsive enough.  i want to move the lettered buttons to the grips.  how would i do this?
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:June 25, 2026, 08:02:25 am
  • I am t3h GAY!!!
Re: Xbox controller hack
« Reply #1 on: November 18, 2005, 10:08:29 pm »
What do you mean hack?
At first I thought you meant for arcade stick use, but then you mentioned flimsy, which wouldn't have any bearing on a gutted for arcade use controller.
The FPS Master is an excellent controller for hacking, especially since you can remap any button to another including the d-pad, and it stores 3 different settings.
As a controller... It could be excellent, and is in concept, but it is definitely flimsy. The triggers being the biggest problem. If you use the controller regularly, then it is pretty much a guarantee that a trigger (most likely the right one) will break.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #2 on: November 18, 2005, 11:43:31 pm »
Yep, i can attest (sp) them being flimsy POSs
Light use, fine.. any real gaming, there toast in a few sessions generally
SithMaster
« Reply #3 on: November 19, 2005, 11:48:58 am »
i wanted to use the design of the fps master but use the more rugged controller s or a gamestop brand one and drill holes on the grips and move the lettered buttons to the grips.  So i would like to know which xbox controllers are best to modify?  Kinda like how certain dreamcast controllers are btter to use than others i have the same question for xbox controllers.
