Author Topic: Jamma Audio Confusion  (Read 2460 times)
tribasic
  • Last login:August 19, 2013, 08:45:50 am
« on: November 18, 2005, 04:27:56 pm »
Hi,
I've been looking up tons of information on the Jamma audio standard. From what I understand, it's mono sound and your speaker must be hooked up to the L 10 pinouts of the jamma harness.
I have a Marvel vs Capcom arcade machine with one speaker. I am missing the speaker on the right side, so I will buy a new one and install it.
The Marvel vs Capcom PCB is stereo. So, does this mean I can wire the second speaker to the M 11 pinout of the jamma harness and get stereo?? I was reading that the M 11 pins are for the Right speaker. I also know that marvel vs capcom pcb has left and right audio out jacks, which could be hooked to an amplifier, but I wanted to know if I could wire stereo sound using only the jamma harness.
And if I did wire the left and right speakers to the L10 and M11 pinouts, what would happen? I don't understand why the M11 pinout for the right speaker is there, if the jamma standard is Mono.
If someone could explain this to me, that would be great.
TriBasic
Ken Layton
  • Guru
  • Technician
Re: Jamma Audio Confusion
« Reply #1 on: November 18, 2005, 06:24:26 pm »
Jamma standard WAS mono. In the early 90's it was changed to stereo. Not every game has stereo audio out though.
tribasic
« Reply #2 on: November 19, 2005, 12:03:30 am »
Thanks Ken!
This is my first arcade cabinet, so I'm still learning lots of stuff.
Thanks to some of your past posts, I managed to get a nice clear picture out of my wells & gardener monitor! You seem to know a lot about arcade machines.
TriBasic
