Author Topic: MySQL server errors on site  (Read 4399 times)
cdbrown
  • Bowowow
« on: January 23, 2003, 10:23:43 pm »
This error message popped up
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 52
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 52
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 53
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 53
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/index.php on line 53
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1008
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1008
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1008
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1009
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1009
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1009
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 140
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 140
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 140
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 142
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 72
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 72
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/index.php on line 72
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/www/html/arcadecontrols.org/yabbse/index.php on line 73
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 75
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/index.php on line 75
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/index.php on line 75
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/www/html/arcadecontrols.org/yabbse/index.php on line 76
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Security.php on line 46
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Security.php on line 46
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Security.php on line 46
cdbrown
  • Bowowow
Re:MySQL server errors on site
« Reply #1 on: January 23, 2003, 10:24:45 pm »
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/www/html/arcadecontrols.org/yabbse/Sources/Security.php on line 47
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1000
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1000
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1000
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1001
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1001
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Subs.php on line 1001
Warning: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 69
Warning: MySQL Connection Failed: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 69
Warning: MySQL: A link to the server could not be established in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 69
Warning: mysql_fetch_row(): supplied argument is not a valid MySQL result resource in /home/www/html/arcadecontrols.org/yabbse/Sources/Load.php on line 70
Anyone know what this is about?
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #2 on: January 24, 2003, 11:10:28 am »
TazMan
  • Last login:January 26, 2025, 03:30:01 pm
  • It's no easy being green.
    • What is the MAMEtrix?
« Reply #3 on: January 24, 2003, 02:39:40 pm »
eightbit
  • My cab is never done...
« Reply #4 on: January 24, 2003, 03:21:21 pm »
Can you post the complete error message I think you missed part of it.
