Author Topic: Windows Screensaver 3D FlowerBox will not delete from XP SP2 (Weird)  (Read 3409 times)
Tiger-Heli
    • Tiger-Heli
This seems odd, I wanted to get rid of some of the default windows screensavers as I never plan to use them.
krick
  • Gotta have blue hair.
Re: Windows Screensaver 3D FlowerBox will not delete from XP SP2 (Weird)
« Reply #1 on: November 12, 2005, 11:24:16 pm »
Windows XP has comething called Windows File Protection that restores certain files if they are deleted, renamed, or modified.
http://support.microsoft.com/Default.aspx?kbid=222193
Some of the nastier viruses going around trick windows into "protecting" their files so that they get restored after the anti-virus programs remove them.
You might be able to remove extra screen savers via add/remove windows components.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: November 14, 2005, 07:06:57 am »
Thanks, Krick!
I think I tried the "Hidden Components thing before" and windows still didn't list the screensavers.  I'll try it again, though.
BTW, according to the PCTG at www.tweakguides.com, you can turn off protection by changing this registry key to 1.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
SFCDisable=0
However, it doesn't recommend doing this, and I don't know what happens if you turn it off, delete the file and then re-enable SFP - I guess I'll find out, though!!!
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: November 15, 2005, 08:43:03 am »
No luck -
Hidden components didn't list the screensaver, and the file still re-appeared after the registry change was made.
However, I re-read the KB article and checked the link and the file is included in Winroot\System32\dllcache.
Question - If I delete it from dllcache and from System32, Windows is supposed to prompt me to insert the WinCD.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: November 16, 2005, 09:22:22 am »
It worked!!!!
Deleted from the DLLcache folder.  Deleted from the system32 folder.  Windows pops up a message that it needed to replace it.  I told it to cancel.  Windows says it will be less stable now (there's an oxymoron).  Screensaver is no more!!!
Thanks for all the tips, Krick!!!
