Author Topic: Monitor  (Read 1797 times)
CPickler
  • Last login:August 20, 2006, 02:37:14 am
    • CPU Studios
Monitor
« on: November 10, 2005, 06:35:06 pm »
I've got a 19 inch Wells Gardner from November of 1988.  I think it is actually the isolation transformer that gave out on my system, but the story is, it isn't working anymore.
I am looking to replace it with another 19 inch arcade screen, prefereably one that doesn't require an isolation transformer.  Where could I go about getting one?  I am in Saint Louis, MO.
Ken Layton
  • Guru
  • Technician
Re: Monitor
« Reply #1 on: November 10, 2005, 06:47:38 pm »
Try www.happcontrols.com or www.arcadeshop.com
Since you're in St. Louis there should be a large coin-operated equipment distributor near you where you can see,try, and buy one in person. Look in your Yellow Pages under the heading of Amusement Devices.
CPickler
    • CPU Studios
Re: Monitor
« Reply #2 on: November 10, 2005, 07:35:30 pm »
Ok, I didn't realize the new monitors required isolation transformers as well.
So the board where the power comes in has three things on it, I believe 1 is the power supply, 1 is the isolation transformer and I am not sure what the other thing is.  I'm going to take a picture.
CPickler
    • CPU Studios
Re: Monitor
« Reply #3 on: November 10, 2005, 07:52:17 pm »
Nevermind, I found the old power switch was grounding the system out.
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: Monitor
« Reply #4 on: November 11, 2005, 05:01:31 am »
its nice when the fault is the simplest one possible
SirPeale
  • Green Mountain Man
Re: Monitor
« Reply #5 on: November 12, 2005, 02:57:47 pm »
You could have eliminated the isolation transformer as a problem by checking it's voltage output with a multimeter.  If it was putting out 110V (or 220, depending where you live) it's fine.
