Author Topic: Fuse rating for AC  (Read 2319 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Fuse rating for AC
« on: November 08, 2005, 12:01:59 pm »
I am in my final wiring stages and wish to know what rating of fuse I should use to go between the plug that goes out to the wall socket, and my on/off switch.
I live in North america, so we're talking 110/120v.
I found a fuse holder and fuse I pulled from a very poorly wired generic JAMMA cab, and it's rated 5A 250. Is this the correct amperage?
NO MORE!!
RayB
  • There's my post
    • RayB.com
Re: Fuse rating for AC
« Reply #1 on: November 08, 2005, 02:25:19 pm »
Found the info on Bob Roberts' site. He says 3A 125v. So looks like my fuse is too high.
NO MORE!!
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #2 on: November 08, 2005, 05:09:27 pm »
It does change from cab to cab, Bob Roberts information is likely intended as a guide - my Terminator machine wont run on anything less than a 5A fuse - and that is also what is stated in the manual, so whatever works for you I guess!
« Reply #3 on: November 09, 2005, 08:58:32 am »
Yeah, it's definitely an individual thing.  You're going to be best served by summing up the amperages drawn by each component in the cab under max load.
RayB
  • There's my post
    • RayB.com
« Reply #4 on: November 09, 2005, 09:32:21 am »
NO MORE!!
« Reply #5 on: November 09, 2005, 09:45:04 am »
You never need a fuse, technically.  It's a safety measure.
I would think you would sum the amp draws, since they are all drawing individually.  If you have 4 items that draw an average of 1.5A, then you are drawing a total of 6A most of the time, yes?
I could be wrong, as I'm still learning EE stuff, but this one just seems common sense.
« Reply #6 on: November 09, 2005, 09:46:19 am »
Would I add them up or average them?
Add them up and make sure your fuse is just above the total max current.
Not sure how it is in the US but in the UK (practically) all appliances have their own fuse in the mains plug so you don't generally have to worry.  Multi-way extension leads tend to have a 13A fuse in them as this covers everything.
2600
« Reply #7 on: November 09, 2005, 09:59:04 am »
Just remember you want to sum the AC current, not the DC current.  Also, you may have to worry about about the initial draw of current which may be higher then the sums you added.  This will cause you to blow your fuse everytime you flip your switch.
Personally, I would just add a surge protector for your situation.
Edit: Rayb, I always read about your project, but still get confused on what you are doing.  Like this example, you are looking for a fuse rating for a JAMMA cab, but you are building a MAME cabinet.  Correct?
« Last Edit: November 09, 2005, 10:08:02 am by 2600 »
RayB
  • There's my post
    • RayB.com
« Reply #8 on: November 09, 2005, 10:23:45 am »
NO MORE!!
« Reply #9 on: November 09, 2005, 10:41:35 am »
2600
« Reply #10 on: November 09, 2005, 10:51:32 am »
That is why we both told him MAX draw, not average draw, for the fuse.
You said max load.  Then you said average draw most of the time.
I'm talking about initial current rush.  There is a difference.
For example, if you have 8 cabs on one circuit breaker.  If you turn them all on at once, the circuit breaker trips.  If you power them all on individually, the breaker does not trip.
« Reply #11 on: November 09, 2005, 10:53:38 am »
Initial draw <= max draw
Always.
It could be that initial draw actually IS max draw, but it may not be max draw.
2600
« Reply #12 on: November 09, 2005, 11:28:57 am »
Chad - I'd argue, but I'm afraid it would be fact vs. opinion which would never end.
RayB - Look at it this way, you now have an optipac for future expansion.
