Author Topic: MAMEWAH HELP PLEASE  (Read 1276 times)
CartmanDP1
  • Last login:October 08, 2008, 05:22:34 pm
MAMEWAH HELP PLEASE
« on: November 05, 2005, 03:32:37 pm »
After testing a lot of front ends i, like many others have chose MAMEwah, but I still can't figure out how to put all my ROMs into categories. I downloaded the catver file and I can go into list settings, generate filtered list, and make a category list called filtered. But is this the only way? The way I'd like it is that MAMEWah opens to a list of categories that you can scroll through, choose and see the games in that category and then go back to the main category menu. This is the way it is in AtomicFE, but I have found that to bee too buggy. Also, MAMEWah has no jukebox, so I have tested a bunch of separate juke programs for cabs, but how do u switch between mamewah and the jukebox? Someone please help.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re: MAMEWAH HELP PLEASE
« Reply #1 on: November 05, 2005, 03:34:24 pm »
stop yelling
did you do a search on the forums? look at the audio forum and it will give you a list of jukeboxes, then you can decided what is right for you.
« Reply #2 on: November 07, 2005, 05:25:04 am »
The filtered lists is the only way to use categories really.
You can use Mamewah to play background music if you want (see the emuname.ini files)...or as papasch said try a jukebox program.
