Author Topic: smaller buttons (height,not width)  (Read 1735 times)
tenrhook
  • Last login:July 31, 2006, 01:14:42 pm
« on: November 04, 2005, 07:40:02 am »
hows it going..
i want to build a classic arcade joystick using metal sheeting..
i have already made one using wood, but i find it to cumbersome to have in your lap.. partially due to its height.. i can't make it smaller with the standard height microswitch buttons..
i saw buttons that would fit my needs at this url:
http://www.highway.net.au/parts/buttons_and_joysticks/4680.html
thing is they dont do credit cards.. and most other sites have a limit whereby u gotta spend over a hundred or something.. and if you dont they tack on 25 extra for there hassle.. i understand why but i'd rather not pay the extra for the sake of 20 buttons..
im in Eire and was wondering if someone knew a more local site that would suffice?..
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Re: smaller buttons (height,not width)
« Reply #1 on: November 04, 2005, 12:41:38 pm »
Happs sells a low profile button similar to the one you posted:
http://www.happcontrols.com/pushbuttons/601200xx.htm
I used these in a set of YDKJ (You Dont Know Jack) low profile controllers and got around the Happ minimum order by buying from ponyboy who is a member of BYOAC and Happs parts distributor.
Not sure if the height requirements fit your needs but another option for you to consider.
tenrhook
« Reply #2 on: November 05, 2005, 04:54:12 pm »
sounds exactly like what i want!..
one question though..
is ponyboy a website or someones username? (i'm new,sorry bout typo)
« Last Edit: November 05, 2005, 10:43:53 pm by tenrhook »
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #3 on: November 05, 2005, 05:02:46 pm »
ponyboy (not body) is a user at this site.  an excellent vendor with rock-bottom prices!
geez...i sound like such a commercial advertisement.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
canoshiz
  • Last login:April 16, 2006, 03:08:17 am
« Reply #4 on: November 05, 2005, 07:33:01 pm »
I read somewhere that those buttons mentioned earlier on Happ's website are the same as Sanwa 24mm buttons.  24 mm buttons are actually very small, and I can't imagine using those as the main play buttons (they are actually used for start buttons in Japanese cabinets).  You could also get the regular type of Sanwa button at www.himuragames.com .  All Japanese style buttons are pretty "low profile", so they would work in your case.
