Author Topic: advmame on 26" 15Khz monitor woes  (Read 1574 times)
skydemon
  • Last login:November 08, 2005, 11:38:24 pm
« on: November 02, 2005, 10:43:04 pm »
Hey guys, Ive got my 26" Nanao 15/25 monitor running both on 25Khz and 15Khz. When its in 25Khz mode there is no problem, however in 15Khz mode I noticed some strange effects on the screen. (its a bit hard to explain but ill try)... basically when there is any vertical movement (say a character jumping up and down) there are a few rows of pixels that dont seem to be updating in sync with the rest of the display, its almost as if there is a row of pixels that are missing (always on the same row of pixels). Has anyone seen this before, can anyone help? Cheers
I hope that makes sense, if not ill try uploading a pic of the screen
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
Re: advmame on 26" 15Khz monitor woes
« Reply #1 on: November 03, 2005, 02:35:53 am »
I had no idea that advmame could do 25khz...
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #2 on: November 03, 2005, 09:15:31 am »
pic of the screen would be helpful...
you seem to suggest that a few rows update out of time, but also mention a row is missing?
First thing I would do is feed a 15Khz signal to the monitor without advmame, and ideally from a completely different source (not your computer) to find out where the problem is coming from.
desmatic
  • Last login:June 25, 2006, 02:25:53 pm
    • Easy MameCab
« Reply #3 on: November 03, 2005, 02:10:38 pm »
sounds like its a vsync issue which could be caused by a number of things.  What's your setup?  Particularly your video card and OS?
skydemon
« Reply #4 on: November 03, 2005, 11:39:16 pm »
its a Geforce2 running on DOS, like I said earlier there's no issues when running at 25Khz, only 15.
Ill try and get soem screenshots soon, cheers
