August 22, 2026, 10:11:05 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Monitor/Video Forum
Connecting a PSone LCD screen to a PC
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Connecting a PSone LCD screen to a PC (Read 4125 times)
markb
Trade Count:
0
Full Member
Offline
Last login:April 30, 2011, 06:41:02 am
The One and Only.
on:
October 30, 2005, 07:46:06 am »
I've bought a PSone LCD screen so I can connect it up to a portable arcade machine however I am having some trouble determining the required connections. I've been searching the boards and googling for the last 2 hours with no luck.
The PSone has a 12 pin connector of which only 9 are used on the LCD as follows:-
PSone LCD
1 Ground Yes
2 Right Audio Yes
3 Ground Yes
4 Left Audio Yes
5 S Video Y Yes
6 Pal TV No
7 S Video C No
8 Video GND Yes
9 Blue Yes
10 +5V No
11 Red Yes
12 Green Yes
Firstly is it possible to connect this to a PC using a composite out cable?
Secondly, what are the connections I would need to make?
I'm just starting to learn about this so any help would be appreciated.
Logged
Jess--
Trade Count:
0
Full Member
Offline
Last login:April 05, 2023, 09:51:55 am
Re: Connecting a PSone LCD screen to a PC
Reply #1 on:
October 30, 2005, 08:30:58 am »
you can connect composite video to a PSone screen, it goes in on the 3.5mm connector by the headphone socket, its an unusual connector with 4 connections instead of 3 (I always wire a phono socket to the board internally).
you can also mod these screens to work with VGA although a lot of people struggle to get the timings right. More details here
http://starfox.ucc.asn.au/carcomp/serio_lcd.htm
Logged
My Botched Mame Cab!
http://www.rtlmanchester.co.uk/arcade
markb
Trade Count:
0
Full Member
Offline
The One and Only.
Reply #2 on:
October 30, 2005, 08:36:53 am »
Unfortunately it's not a Sony brand LCD so it does not have a composite input. Also for the VGA hack I believe it requires a +5V connection so that the PC can turn it on, and it doesn't have one of those either. It may still work as a VGA but I TV out would be preferable.
Logged
Jess--
Trade Count:
0
Full Member
Offline
Reply #3 on:
October 30, 2005, 08:57:06 am »
what type of psone screen is it, most do have composit input somewhere.
Logged
markb
Trade Count:
0
Full Member
Offline
The One and Only.
Reply #4 on:
October 30, 2005, 09:12:53 am »
Bigben Interactive make the screen, and I cannot find any information on it at all. The only input socket it has looks to be for headphones.
I have worked out though it gets its picture from the Psone using
S-Video Y
Red
Green
Blue
No idea how to get this signal from a PC yet.
Logged
markb
Trade Count:
0
Full Member
Offline
The One and Only.
Reply #5 on:
November 05, 2005, 06:56:58 am »
The power supply arrived today and the screen boots up no problem on my old PS1, still no joy connecting it to a pc yet.
I've tried various combinations of wires and worked out that it requires and RGBY (or yRGB) signal to work the Y being the Luminance. I'm still hunting around to try and find out if this is possible to get from either a VGA output or TV-output.
In the meantime does anyone know if this is even possible?
Logged
markb
Trade Count:
0
Full Member
Offline
The One and Only.
Reply #6 on:
November 06, 2005, 05:14:48 am »
I'm posting this just in case anyone else tries this at a later date and the link is useful as well so forgive me for continuing the thread.
I finally got it working this morning after finding this useful article:-
http://lagnarok.no-ip.com/index.html
I hooked it up using the following:-
VGA LCD Input
Red Red
Green Green
Blue Blue
Ground Ground
H Sync S-Video Y
V Sync S-Video Y
Using powerstrip on an old Matrox G100a I had lying around I was able after a lot of tweaking to get a reasonable picture by using the Arcade setting. Also I used Real VNC so I could play with the settings and not change over the vga plug constantly.
I would recommend though buying an official Sony screen as the resoluton on the one I have is not very good at all.
Logged
StephenH
Trade Count:
0
Full Member
Offline
Last login:January 09, 2023, 06:15:45 am
I'm a llama!
Reply #7 on:
November 06, 2005, 05:41:43 pm »
Most PCs have a +5V output. In fact, the easiest place to get access to it, is an unused disk drive connector.
Also, there are some external transformers that supply 5V too.
Logged
https://www.viagrasansordonnancefr.com/sildenafil-100-mg-ligne-wirkungsdauer/
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
