Author Topic: Joystick question - Single or Double pole  (Read 1230 times)
AC.
  • Last login:January 21, 2015, 03:55:07 pm
    • MAME console
« on: October 23, 2005, 02:58:02 pm »
I need two small joysticks and am looking at this one at Happ:
http://www.happcontrols.com/joysticks/503050a1.htm
What does the "Single or Double pole switched" mean?
NoOne=NBA=
Re: Joystick question - Single or Double pole
« Reply #1 on: October 23, 2005, 03:13:36 pm »
Single pole means that it closes one switch when activated, like a lightswitch would.
Double pole means that it will close two switches when activated.
An example of this would be if you glued a popsicle stick across the lightswitch and fan switch in your bathroom.
Shoving up on the popsicle stick would activate BOTH switches at the same time.
AC.
    • MAME console
« Reply #2 on: October 23, 2005, 03:44:43 pm »
Thanks!  So that means I only need a single pole switch, unless I wanted to control two functions at the same time.
