Author Topic: setting up resolutions for the first time  (Read 2574 times)
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« on: October 17, 2005, 03:48:58 am »
hi. i wanna use advancemame/menu using an rgb monitor, how do i set it up the first time, coz i figure that it cant display correctly at first so how do i go and navigate in dos mode like in advcfg,advv etc. thanks.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: setting up resolutions for the first time
« Reply #1 on: October 17, 2005, 11:45:13 am »
use a normal PC monitor first.
NO MORE!!
starcrudph
« Reply #2 on: October 17, 2005, 08:38:55 pm »
ok thanks, any more tips and advice?
RayB
  • There's my post
    • RayB.com
« Reply #3 on: October 17, 2005, 11:21:12 pm »
Print out the installation files. They are very lengthy and you WILL need to consult them as you're going along configuring settings. It's not very straight-forward, so follow all instructions closely.
NO MORE!!
gmorse
  • Last login:July 01, 2007, 10:02:25 pm
« Reply #4 on: October 18, 2005, 10:43:52 pm »
what are you using for a graphics card and are you using a jpac?  Dos or Linux?
You might also want to keep arcadeos in mind if advmenu gives problems.  I had no problem getting advmame working with games from the command line, but for whatever reason I couldn't get advmenu to work.  Kept giving me a no supported graphics mode error.  Arcadeos worked like gangbusters though.
RayB
  • There's my post
    • RayB.com
« Reply #5 on: October 20, 2005, 11:50:45 am »
NO MORE!!
gmorse
« Reply #6 on: October 20, 2005, 09:42:31 pm »
Yeah, I did that and I still couldn't get it to work.  Got frustrated as hell after a few hours and just switched to arcadeos, which worked the first time, so I never bothered going back and trying to figure it out.  I'm sure it's something stupid like I fat-fingered a character in the advmenu.rc.  One of these days I'll go back and get it working, but arcadeos has been pretty good for me so far.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #7 on: October 21, 2005, 01:34:17 am »
You need to copy over the graphics mode info from your ADVMAME.rc file over to the ADVMENU.rc file.
This is how advmenu works:
If there is a modeline called "default_graph" available it will be used. All other modelines are ignored.
If "default_graph" isn't found it will use the parameters display_width and device_video_format to generate a modeline.
Best way to run advmenu is to calibrate a modeline that looks fine on the monitor and then call this "default_graph"
