Author Topic: mounting a star wars yoke in wood panel  (Read 1543 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: October 16, 2005, 08:19:34 pm »
anyone have any suggestions?  the built in bolts on the yoke are less than 3/4 inch in lenght.  I could route out the 3/4 mdf I'm using for my panel, but wonder about the strength of what's left.
anyone got one of gamecab's yokes?  how does it mount?
thanks,
Tailgunner
Re: mounting a star wars yoke in wood panel
« Reply #1 on: October 16, 2005, 11:06:14 pm »
I'd mount it using sex nuts. They're a tubular form of bolt that would allow you to mount the yoke base without routing any thickness out of your control panel.
« Reply #2 on: October 17, 2005, 07:38:11 am »
Can you get these with a head you can put a spanner/socket on?  The one in the diagram looks like a carriage bolt head which wouldn't work here I don't think since the bolts are fixed to the yoke.
quarterback
« Reply #3 on: October 17, 2005, 11:38:34 am »
All I can say is "Beware" if you search Google Images using the term "sex nuts"
I had no idea that's what those were actually called.
-- Chad Tower
Tailgunner
« Reply #4 on: October 17, 2005, 07:32:26 pm »
Minwah: Can you get these with a head you can put a spanner/socket on?  The one in the diagram looks like a carriage bolt head which wouldn't work here I don't think since the bolts are fixed to the yoke.
Probably, though usually they're slotted for a straight bladed screwdriver.
quarterback: All I can say is "Beware" if you search Google Images using the term "sex nuts". I had no idea that's what those were actually called.
Heh,  no kidding. It's probably safer to run your search using "sexnut" or "sexbolt". Quite often you only find the bolt and nut sold as a pair. I learned about them while installing commercial bathroom partitions, as they're typically put together with sex bolts. The heads on those have the slots ground away on one side to keep people from removing them. A sexbolt is a fairly specialized type of hardware, but occasionally I run across a situation where they work when little else will do the job.
