Author Topic: Help w/ Star Wars Yoke Potentiometers and limit stops  (Read 1238 times)
Major Rock Hardy
  • Last login:April 29, 2013, 06:51:45 pm
  • xybots rocks!
« on: October 11, 2005, 10:21:41 am »
OK I am cleaning up a star wars yoke, putting it back together with some spare parts that the seller included when I bought the yoke.  The up/down axis pot and gears seem to be fine (however I'll need to hook new wires up).  However, the left/right axis is not right.
I have installed the pot on this axis and rotated the yoke clockwise (CW) until the hard metal limit stop was reached (approx. 90 degrees to the right).  I then turned the pot to its mechanical limit in the appropriate direction and installed the gear.  Now when I rotate the yoke the other direction (CCW), the mechanical limit of the pot (delicate) is reached a little bit before the limit stop of the actual yoke (durable).  When the limit of the pot is reached, there is about 1/4" between the yoke stops.  This is far from ideal as I see this scenario trashing the pot eventually.
So as far as I can guess,  either:
1) the pot has not enough rotational ability (were multi-turn pots ever used on yokes?)
2) the limit stops on the yoke are in the wrong places for some reason
3) the gears happen to mesh beautifully but are the wrong gears and hence the pot is turning at too fast a gear ratio
4) there should be some kind of thick (rubber?) bumper on the yoke limit stops that would reduce the overall range of motion of the yoke (right now it is 2 thick metal pins that strike each other when the limit is reached).  Thick enough that it would make up the 1/4" difference.
any help would be great... thanks!
Rock
Flinkly
Re: Help w/ Star Wars Yoke Potentiometers and limit stops
« Reply #1 on: October 11, 2005, 02:43:43 pm »
your stops should have rubber bumpers, but they have been known to degrade into black goo, so your's were probably "cleaned" up some time ago.
« Last Edit: October 11, 2005, 02:49:28 pm by Flinkly »
rdagger
« Reply #2 on: October 11, 2005, 06:45:41 pm »
You might double check that the pot is off center too much in one direction.
NoOne=NBA=
« Reply #3 on: October 11, 2005, 07:31:59 pm »
I used vinyl tubing over the original metal part of the stops--after I spent forever getting the black goo off that USED to be rubber.
The vinyl shouldn't degrade like the rubber ones did, and provides enough cushion to work properly.
