Author Topic: Mamewah problem with Mame .100 update  (Read 3388 times)
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« on: October 08, 2005, 10:40:20 am »
Hey guys, I recently updated from an older Mame (.94?) to .100 and I'm having these 2 problems. I've tried a few things to figure this out but I'm not getting anywhere.
1. In Mamewah 1.61, I can't generate my main games list with ALL available games. Which listgen method should I be using to generate a list of all games? Whatever was the default worked with my older version but not the new one.
2. In Mame, in the Tab menu, I no longer see a Game History option. I have history.dat in my Mame folder.
Any help with these two issues appreciated.
I mainly upgraded for the Robotron issue and I love the new version!
Thanks.
*title edited after history Q answered
« Last Edit: October 08, 2005, 02:52:51 pm by JCKnife »
SirPeale
  • Green Mountain Man
Re: Couple problems with Mame .100 update
« Reply #1 on: October 08, 2005, 11:39:22 am »
Support was removed from Mame because so many front ends support the history.dat function.
mahuti
« Reply #2 on: October 08, 2005, 01:19:31 pm »
And according to Haze... history.dat (among other things) SHOULD be removed from mame because it doesn't necessarily aid in the preservation function of mame.
JCKnife
« Reply #3 on: October 08, 2005, 02:44:26 pm »
Dang, that's too bad--I always liked the History. I think it aided preservation tremendously.
Does Mamewah 1.61 support it? I'll have to look that up.
Any ideas on my listgen problem?
« Last Edit: October 08, 2005, 03:47:51 pm by JCKnife »
JCKnife
Re: Mamewah problem with Mame .100 update
« Reply #4 on: October 08, 2005, 03:47:16 pm »
I was able to generate a list using rom_folder_vs_listxml but the list is only showing 3166 games.
I have a full rom set
A CMP scan shows something like 5788 games.
What am I doing wrong?
jcrouse
    • CPViewer
« Reply #5 on: October 08, 2005, 06:08:44 pm »
rom_folder_vs_listxml is the method you should be using. It sounds like an issue with clones, although I'm not sure what the problem is. You are not inside a custom list, are you?
John
JCKnife
« Reply #6 on: October 08, 2005, 06:15:25 pm »
Yeah, I realize now this is a clone issue. Yes, I'm definitely on the main list, and I DO want to show clones but they're not showing up.
I'm using merged sets. Is that the reason?
Off to try "search" again...
JCKnife
« Reply #7 on: October 08, 2005, 06:21:06 pm »
Okay, this is a little embarassing but I found my answer in one of my old posts in this thread:
http://forum.arcadecontrols.com/index.php?topic=14382.0
However, the solution no longer works. I set my list gen method to "verifysets_vs_listxml" but this generates an empty list.
Since my version of Mamewah did not change, I'm assuming Mame .100 no longer supports this list generation method.
So now what?
« Reply #8 on: October 09, 2005, 01:26:24 pm »
That's right...they removed -verifysets...so basically you are stuck.  The only solution is to un-merge your sets using ClrMAME...
JCKnife
« Reply #9 on: October 09, 2005, 07:30:01 pm »
But...I can run mame with -verifysets in a dos window and it works...
Also I have a list of all games (including clones) generated as a "have list" text file from clrMame. Is there any way to use that text file as a games list?
jcrouse
    • CPViewer
« Reply #10 on: October 09, 2005, 07:35:41 pm »
No.
John
« Reply #11 on: October 10, 2005, 05:09:44 am »
Are you sure you have MAME v0.100?  I'm sure this option was removed a few versions ago - just tried it with v0.101 and it is not there.
JCKnife
« Reply #12 on: October 10, 2005, 09:10:10 pm »
« Reply #13 on: October 11, 2005, 05:12:06 am »
Whoops, my mistake--what I used is -verifyroms.
Is this the same thing or not?
No, -verifysets checks whether romset(s) are good & -verifyroms checks each rom in a romset and will report back bad dumps etc.
