Author Topic: ACT LABS GUNS - Which one?!  (Read 896 times)
Jellyman_4eva
  • Last login:January 26, 2006, 04:21:22 am
« on: October 08, 2005, 05:09:15 am »
Hi
I have a bit of a quandry going on. I have a large CRT multisync monitor, which is connected to two systems via  a KVM. One system has a Arcade VGA and runs the monitor at 15KHz, whereas the other has a Nvidia 6600 and runs it at 31Khz and above.
I would like a gun which is compatible with both of these boxes, and was not sure whether it would be the ACT Labs PC version or the TV version (because I am running it at a PC rate on the Nvidia and a TV rate on the Arcade VGA).
I got the impression from their website that the only difference between the two units was the connection box, one had VGA and the other had S-Video... is this true, or are the actual specifications different?!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: ACT LABS GUNS - Which one?!
« Reply #1 on: October 09, 2005, 01:47:39 am »
I believe the vga version is what you need.  I don't work for Act-Labs tech support, though, so don't take my advice as the gospel.
