Author Topic: MameWah Layout Problem  (Read 1003 times)
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
« on: October 07, 2005, 08:00:52 pm »
     Hi all...
I "finally" got mamewah up and running with different emulators! My problem now is I cant switch the layout from emulator to emulator. Example...I only have Atari 2600 and Nintendo set up on MameWah. There fine when I set them up for the 1st time and switch the layouts...NO PROBLEMS! but when I add the 2nd emulator in there...it still reverts back to the layout I set up the first time. I do have  configuration files for both emulators and the different layouts are set up in individual folders and names proberly related to the emulator I want it to show up on.I got these off of JCROUSES website and I changed the ini files to refer to where I have them placed and named on my hard drive. THIS WORKED GREAT, THANKS!!! Is there suppose to be only 1 "Mamewah" config setting? I think I still might have to change something in the emulator ini settings somewhere...the last prompt on there reads
settings used by mamewah
current list   0
What do I need to change yet to make this work? Thanks in advance
Dan
sportswizdan
Re: MameWah Layout Problem
« Reply #1 on: October 07, 2005, 08:15:16 pm »
OK...I figured it out!!! I had the 2- emulator layouts in DIFFERENT folders in the mamewah\layouts. I put them in the SAME folder but still had the individual files realted to the emulator ini files. Thanks anyway! :)
