Author Topic: Atomic FE and samples  (Read 1301 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: October 05, 2005, 04:51:46 pm »
Can somebody help me to get the sound samples working in atomic fe, ive put them in the samples folder in the mame dir but they dont seem to work, also how can you enable cheats using atomic fe
sorry if its been asked before but info on atomic seems to be a bit thin
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Atomic FE and samples
« Reply #1 on: October 06, 2005, 03:13:22 am »
Hi ,
Your problem is not related to Atomic.
For the Samples, be sure that your samples file which is in the MAME\Samples directory has exactly the same name than the rom file. and it should work.
To enable cheat , it is a MAME configuration too. Atomic has no specific options for emulators , it only run game according to your emulator configuration.
I don't use cheat for MAME , but i know others do .(including Atomic Users). If nobody answer here , i suggest you do another post asking "How to enable cheat with MAME"  or may be better do a search on the forums i bet there should be already the answer.
Hope it helps.
