Author Topic: RESOLVED.. vertical line down middle of WG K4600  (Read 2270 times)
BenDalton
  • Last login:May 29, 2012, 09:28:07 am
  • KingsQuest was the sh*t. I miss old-school Sierra
« on: October 04, 2005, 02:53:23 pm »
So, I have a 19k4655 monitor that I just got, a T64 Blade video card @ 15hz, and now my display just has a vertical line going down it. The monitor his mounted horizontally. The line, with no video signal, is about 1/2 inches across, and with video it is about 1/5 an inch.
Help! Any ideas?
-Ben
« Last Edit: October 04, 2005, 04:45:14 pm by BenDalton »
BenDalton
Re: Help.. vertical line down middle of WG K4600
« Reply #1 on: October 04, 2005, 03:30:11 pm »
would a disconnected wire cause this??
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #2 on: October 04, 2005, 03:38:50 pm »
If you have a single vertical line, I believe that is a loss of horizontal deflection (experts can correct me if im wrong), you seem to be missing a yoke wire there (only 3 ??) which would explain that
BenDalton
« Reply #3 on: October 04, 2005, 04:44:59 pm »
After some help from CW in the IRC channel, I figured out that that (the ground wire which was disconnected from the yoke) was indeed the issue.
