Author Topic: S-video/Gun vs. Component Video Which is worth it.  (Read 1447 times)
JabbaTheFart
  • Last login:November 22, 2006, 09:58:30 am
« on: October 04, 2005, 09:12:45 am »
I have a question.  I have a 24 inch TV i bought for a cabinet that i am building.  it is a Insignia
Skadar
  • Last login:August 07, 2017, 02:20:01 pm
  • I love my new Corsair keyboard: RRRrrrrrr!!!!
    • Ooine.com
Re: S-video/Gun vs. Component Video Which is worth it.
« Reply #1 on: October 04, 2005, 10:58:40 am »
Did you read the last post in that thread?   ;D  I posted a link to some screenshots I took to help you compare s-video to component.  Here's the link.
http://forum.arcadecontrols.com/index.php?topic=43408.0
I've been using component video for the past couple of weeks and I can't say that I'm 100% happy.  There always seems to be a trade-off.  For me, the trade-off is video flicker versus a sharper picture.
Both are equally noticable, so it's just a matter of which is more important to me... unless I can find a solution to the flicker that doesn't involve buying an HDTV.
The component video is much sharper to me.  I like a lot of vector games and vector on s-video just doesn't cut it for me.  However, the component video introduces a lot of flicker that I am rather sensitive to... whereas the s-video is rock solid.
Sigh.... it's never easy.   :-\
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
« Reply #2 on: October 04, 2005, 02:44:09 pm »
Try them both with your TV set, and your computer.  Sometimes it's better, sometimes its worse.
Often the s-video port is stuck on the back, and just wired together inside with a cap (your basic s-video to composite adapter at radio shack) - in essense, its just a composite video input with an s-video connector for convenience.
Likewise, sometimes component video inputs, if the TV doesnt support progressive scan or high def, are basically the same deal.  The jacks are there for convenience, with a cheap analog component to composite adapter inside.  In fact, if your TV doesn't support progressive scan, and therefore only component video at 480i (regular old video), you probably wont see a difference between s-video and component.
In fact, on my Phillps 27" set, s-video looks better to me than component, I was pretty dissapointed to blow 20 bucks on component video for my PS2 only to find out it looked somewhat washed out.
Though in the end, to me at least, it's like the frame rate wanking on PC game forums.  If you can notice the difference between 50 fps and 53 fps, or see little jaggies in the distance, then either the game you're playing sucks or you aren't much of a gamer.  My point is, you'll be looking at the game you're playing, not the screen.
(quick history - composite ntsc was the format that laserdiscs stored, which is when they started appearing.  S-Video was the format that SVHS tapes stored, which is when they appeared.  DVDs store video in component video, so now they're standard.  The good-better-best thing people spout is not a hard and fast rule, like I said above, if the TV has cheaper components and S/Video or Component was added for convenience, don't be surprised if it doesn't look as good as you expect, or even worse.)
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #3 on: October 04, 2005, 03:34:45 pm »
I dont know what experiences other people have with this, but with my computer the S-Video output is truly awful... It's strange, with S-VIDEO input the picture is flickery, off-coloured, very bad quality.. I hacked in an RCA Jack into the S-VIDEO cable (for the guncon 2 =)) and the picture is PERFECT.. I know you're comparing component/s-video and not composite/s-video, but I thought I'd give my $0.02..
ADD: Don't make your decisions based off me, there's a good chance its my TV has a dodgy jack on it, hell if I'm running off scart/composite/component/s-video (basically anything) I get sound from channel 1 as well as the sound and video from the input.. but thats another story ;P
« Last Edit: October 04, 2005, 03:44:06 pm by Nipedley »
