Author Topic: what jostick is needed  (Read 2878 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
« on: September 30, 2005, 07:45:50 pm »
hey all what joystick would be needed to use like an xbox analogue stick for my cp? i know its not a 4 way but would an 8 way do? or what do i need?
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
Re: what jostick is needed
« Reply #1 on: October 01, 2005, 10:39:13 am »
Uhm, if you want to have analog controls for your Xbox games maybe you should use an Analog controller.  Otherwise the best you can do is to use an Ultimarc Xbox adapter and hook an 8-way joy to it.  It will act like you are pressing the analog stick at maximum pressure in 1 of 8 directions.
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
« Reply #2 on: October 02, 2005, 12:17:47 pm »
It could be done, but you would need to use expensive analog joysticks.  Roughly 90 bucks a pop.  Then you would have to hack it to your xbox controller pcb.  I know I am not up for 300-350 in parts for an xbox controller.
Goz
  • KOTA
« Reply #3 on: October 02, 2005, 04:30:56 pm »
The X-arcade BYOA kit will allow you totoggle between analog and digital mode for whichever jioystick is connected but as mentioned with the Ultimarc solution it is as if it is at maximum pressure.
-Goz
