Author Topic: Jamma to TV  (Read 1420 times)
GuinnessGuy74
  • Last login:November 08, 2011, 11:01:43 am
Jamma to TV
« on: September 30, 2005, 05:02:27 pm »
I know this question has probably been asked a thousand times, but every topic I see deals with standard resolution.
I am looking to build a travel version of Golden Tee (basically just a control box which can hook up to a TV).  I am looking into 2004 or 2005 both of which use medium resolution. Is possible to convert mid res to output on a normal TV?
If this IS possible, will the image quality be reduced dramatically?
Thanks for all the help!!
Jim
Ken Layton
  • Guru
  • Technician
Re: Jamma to TV
« Reply #1 on: September 30, 2005, 05:56:06 pm »
Don't those gameboards have a dipswitch to select monitor resolution (CGA or EGA)?
GuinnessGuy74
Re: Jamma to TV
« Reply #2 on: September 30, 2005, 06:20:39 pm »
Actually, I think you are right! Do you know how the game looks in Standard mode??
On an off topic, is there a way to convert a Std res arcade monitor to a Med res?
thanks for the reply Ken!!
Jim
