Author Topic: Please recommend a DOS FE  (Read 2732 times)
spystyle
« on: September 25, 2005, 06:27:56 pm »
Howdy,
I am going to try to get DOS running on my daughter's cab, can you guys recommend a good FE?
Thanks,
Craig
TheVengeance
  • Banned
  • Last login:October 19, 2005, 05:31:38 pm
  • Banned
Re: Please recommend a DOS FE
« Reply #1 on: September 25, 2005, 06:38:30 pm »
I'm pretty sure GameLauncher will be what you're looking for.
http://www.dribin.org/dave/game_launcher/
It's good for a standard pc monitor. Otherwise you can laways use AdvanceMenu or ArcadeOS.
Banned
SirPeale
  • Green Mountain Man
« Reply #2 on: September 25, 2005, 06:46:06 pm »
ArcadeOS.
spystyle
« Reply #3 on: September 25, 2005, 07:24:56 pm »
Thanks, I will take a look at those 3
Just wanted to know my options, are there any other DOS frontends worth mentioning?
Craig
jcrouse
    • CPViewer
« Reply #4 on: September 25, 2005, 09:27:51 pm »
I used MameMenu in my old DOS days and was quite happy with it. It's VERY easy to set up.
http://edsfamily.com/ed/mamemenu/
John
spystyle
« Reply #5 on: September 17, 2006, 09:29:59 pm »
Rock on fellas,
I had good luck with mamemenu and game launcher, I found arcadeOS and AdvanceMenu to be complicated.
Mamemenu crashed unless I had it set to "resolution 2" and was somewhat unresponsive when scrolling the menu, otherwise was super easy to set up and super simple to use. Good if you want simple and easy.
GameLauncher is probably the best if you want to run multiple emulators, a little more difficult to set up but pretty solid afterward.
I am experimenting with old PII computers - I have DOS 7 (via Fraggal's boot CD) and dmame .61 running very fast by setting mame's resolution to  320x240 and sound to 11025 khz. I am also using GeForce video cards (that probably helps)
These "anchors" can power cabs if you ditch WinSlows!
Cheers,
Craig
Chris
    • Chris's MAME Cabinet
« Reply #6 on: September 18, 2006, 04:05:19 pm »
I would second the GameLauncher recommendation; that's what I used when my cab was DOS.
--Chris
spystyle
« Reply #7 on: September 18, 2006, 07:40:00 pm »
OK good buddy,
I'll do it!
