Author Topic: Construction materials  (Read 1621 times)
Mr. Bubblehead
  • Last login:May 16, 2007, 08:49:19 am
  • I use soap.
« on: September 21, 2005, 10:30:14 am »
In reading through the forums I've noticed that the majority of you build your stuff with MDF, as opposed to traditional particle board like most arcade games were traditionally made of.  I'm curious why that is...it has been my experience that particle board holds up a lot better over time, not to mention it's less expensive.  Is it because MDF is easilr to work with and has a smoother finish?
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
Re: Construction materials
« Reply #1 on: September 21, 2005, 10:41:46 am »
I've never built a cab, and I'm no expert, but I'd say it's all about the finish.  Plastic laminate and laminating paper are difficult/crappy to work with.  You can paint mdf with minimal sanding.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
rescue161
  • Last login:August 04, 2025, 05:20:11 pm
  • I built my own Cabaret machine!
« Reply #2 on: September 21, 2005, 01:32:08 pm »
I built mine out of plywood.
My original Pac-Man is made of plywood.  I'm glad too as partical board just wouldn't have withstood the test of time.
It's lighter and holds up better than MDF in my opinion.
"Censorship reflects a society's lack of confidence in itself." - Supreme Court Justice Potter Stewart
webgeek
  • Last login:August 08, 2006, 07:05:10 pm
« Reply #3 on: September 21, 2005, 01:39:33 pm »
Mine will be plywood as well.
Mike
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« Reply #4 on: September 21, 2005, 01:48:32 pm »
Mine is plywood.
Really depends on the quality of plywood and if you plan on painting or using lamanate.  If you use low grade plywood that has rough surfaces, painting it would look like crap.
Think MDF is easier because it is smooth but I believe it is heavier than a equal thickness plywood.
Teamwork - A group of people running around doing what I say.
Mr. Bubblehead
  • I use soap.
« Reply #5 on: September 21, 2005, 01:54:48 pm »
I just wondered if there was some secret advantage of using MDF that I didn't know about.  All my cabs are constructed of part board, but I reinforce them well and I also have a method of sealing the surfaces to make them perfectly smooth as well as moisture and chip-resistant.
Tailgunner
« Reply #6 on: September 21, 2005, 02:11:05 pm »
Plywood is stronger, but it warps and delaminates when wet, and unless you're talking marine grade plywood it has voids in it. Marine grade plywood is significantly more expensive than MDF.
As to MDF versus particle board, MDF cuts and routes nicer, and needs minimal surface prep to finish. The cabinet making industry switched a long time ago to MDF for that reason.
The arcade cab manufacturers of the golden era were stuck with what they could get to build the cabs. Demand for the cabs was huge, and sourcing the materials for a several thousand cab production run ment they had to make do with what was available in sufficient quantities.
Skadar
  • Last login:August 07, 2017, 02:20:01 pm
  • I love my new Corsair keyboard: RRRrrrrrr!!!!
    • Ooine.com
« Reply #7 on: September 21, 2005, 03:14:58 pm »
I went with 3/4" birch plywood for the cabinet I'm building now.  I personally can't stand MDF.  I don't want to build with stuff that I can pull apart with my bare hands.
The 3/4" birch plywood that I am using costs $45 a sheet.  Money well spent in my opinion.
« Last Edit: September 21, 2005, 05:07:19 pm by Skadar »
MameJunkie
  • Eeeeeeeevil
« Reply #8 on: September 21, 2005, 04:05:31 pm »
Tailgunner is right about the warping of the wood.  I have that problem with my cab.
  • Last login:May 07, 2026, 02:27:41 pm
« Reply #9 on: September 21, 2005, 04:32:52 pm »
I really don't like MDF.
