Author Topic: IPAC/Opti vs. Mini-pac  (Read 5479 times)
miles2912
« on: September 18, 2005, 06:54:42 pm »
Am I missing something here.  The Mini pac comes with all the connections that the I-PAC comes with plus a wire harness and Optical connect for a trackball/spinner.  The price is a little cheaper than the ipac/opti pac combo plus you get pre wired wires.  I can see a problem if your controls are further apart than the harness, but other than that the mini-pac sounds like a great deal.
Anyone care to comment?
Miles
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: IPAC/Opti vs. Mini-pac
« Reply #1 on: September 18, 2005, 07:32:25 pm »
Yea, the Mini-Pac is a great deal.  Especially if you have the inclination to make your own wiring harness.  The Opti-Pac allows you to hook up multiple trackballs / spinners, but if you're only using one then the Mini is the way to go IMO.
-Ace-
I want my own arcade controls!
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: September 19, 2005, 08:14:21 am »
Depends if you want dual trackballs or only one.
<edit> Ooops - AceTKK already said that. . .
miles2912
« Reply #3 on: September 20, 2005, 01:57:21 am »
Hmmm ...  According to the Mini-Pac wiring page it shows inputs for 2 tracballs plus a spinner.  Am I reading it wrong?
Miles
LiquidFire
  • Last login:February 11, 2022, 09:22:19 pm
« Reply #4 on: September 20, 2005, 04:37:05 am »
After reviewing the info, I decided that for my upcoming cabinet I wanted the I-PAC / OPTIPAC combo for the total mind-numbing number of inputs allowed. Can't be sorry going that route even though I will never need it.
However, for a second project I am building a control panel standalone for the 'squids' and I chose the Mini-Pac & harness since I won't change it once it is done.
The major difference from an engineering standpoint IMO is the ruggedness of the parts. The I-PAC is certain to last and taste better longer.
For sheer productivity, nothing will beat the Mini-Pac. As Andy says, geared toward OEM cab builders. The small design probably benefitted from some generational lessons. If I was building to sell, I would use it and the pre-made harness to save time.
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: September 20, 2005, 08:41:15 am »
Miles
http://www.ultimarc.com/mp_inst.html
Yes, but I see how you got confused - Trackball X - X (horizontal axis), Trackball Y - Y (Vertical axis).
One trackball and one spinner as opposed to two trackballs and four spinners.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #6 on: September 20, 2005, 01:33:43 pm »
So you can do one track ball and one spinner?
Yes, Timoe, this is correct
« Last Edit: September 20, 2005, 01:49:57 pm by timoe »
miles2912
« Reply #7 on: September 20, 2005, 07:15:57 pm »
.. and that is exactly how I am going to use sit.  One trackball and one spinner.   I placed the order (shipping number sent the same day!) and am looking forward to putting it all together.
Miles
